Peterla Posted October 17, 2007 Share Posted October 17, 2007 Does anyone know if i can fit the factory roof rails to my 200 tdi. I am not sure if this is a factory process or I can refit them from a wrecked car. Thanks Peter Quote Link to comment Share on other sites More sharing options...
Mark Posted October 17, 2007 Share Posted October 17, 2007 The two front rails are relativly easy to fix to a car that didn't come with them. The holes are already in the roof supports, so you nee dto drop the headlining and find the four holes, then drill through the outer skin. I belive it is then just a case of bolting the rails in place then with a suitable amount of sealer... If you are taking them off the wrecked car too, I guess it will make working out where the holes go that much easier. hth Mark Quote Link to comment Share on other sites More sharing options...
