Dorsetfreelander Posted October 21, 2007 Share Posted October 21, 2007 I have a Freelander TD4 SE auto 04 reg with 24k miles on the clock. Some mornings when I drive off there is a noise like a whining noise (not too loud) which lasts about 15 seconds as if something is pumping up or being pressurised. Occasionally during the day it might happen again when pulling away. If I stop the car whilst this is happening it makes no difference. Any suggestions what this might be? Thanks Dennis Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 22, 2007 Share Posted October 22, 2007 Is it fitted with a fuel burning pre-heater? Could be that if so Quote Link to comment Share on other sites More sharing options...
MJIbex Posted October 22, 2007 Share Posted October 22, 2007 Is it fitted with a fuel burning pre-heater? Could be that if so The Bogmonster is right an 04 plate UK Spec SE will have a fuel burning heater which will kick in automatically in low ambient temps when the engine is cold. To confirm it is this in front of your n/s/f wheel will be a approx 3/4 inch pipe which is the exhaust from this; if you feel warm air from this when you hear the noise all is normal. Mark Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted October 23, 2007 Author Share Posted October 23, 2007 The Bogmonster is right an 04 plate UK Spec SE will have a fuel burning heater which will kick in automatically in low ambient temps when the engine is cold. To confirm it is this in front of your n/s/f wheel will be a approx 3/4 inch pipe which is the exhaust from this; if you feel warm air from this when you hear the noise all is normal.Mark Thanks, yes it is supposed to have a fuel burning heater although at the moment the heater control is turned right down. Would you expect it to cut in regardless of the heater position? Thanks Dennis Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 24, 2007 Share Posted October 24, 2007 Yes because it is as much about engine warm up as heater warm up, to reduce engine wear by not having it running cold all the time. The FBH should come on in any ambient temperatures below 5 deg C (sensor behind the grille which sometimes doesn't work!) until the engine coolant gets to a set temperature, and then shut off, and will cycle on/off if the engine coolant keeps dropping below that temp due to slow running, idling, the heater being on full blast or whatever. Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted November 5, 2007 Author Share Posted November 5, 2007 Yes because it is as much about engine warm up as heater warm up, to reduce engine wear by not having it running cold all the time. The FBH should come on in any ambient temperatures below 5 deg C (sensor behind the grille which sometimes doesn't work!) until the engine coolant gets to a set temperature, and then shut off, and will cycle on/off if the engine coolant keeps dropping below that temp due to slow running, idling, the heater being on full blast or whatever. OK but since it only comes on for about 10-15 seconds I can't believe that it would warm the engine up that quickly (and it hasn't been that cold ie below 5C recently ) Quote Link to comment Share on other sites More sharing options...
denviks Posted November 5, 2007 Share Posted November 5, 2007 we have a 55 plate freelander td4 and it does the same thing ...i have been alittle worried about it too...its only started over the last month or so Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted November 8, 2007 Share Posted November 8, 2007 Mine used to do the same, though it was more of a groan than a whine. Any cracks about my weight will be ignored. It also did it in the summer, but was still the same after the dealer was asked to look at it. Perhaps that was the cause of the very disappointing 28mpg? A case of "They all do that sir!" Quote Link to comment Share on other sites More sharing options...
jules Posted November 8, 2007 Share Posted November 8, 2007 It should be doing more than 28mpg, not much more but should be a little better. Unless it only does town driving in which case its quite good. Now I'm just confusing things aren't I Its hard to know my old Td4 racer would do about 60-80lt to 100miles on a good open track less if it was a technical stage Quote Link to comment Share on other sites More sharing options...
JCB Posted November 8, 2007 Share Posted November 8, 2007 Our TD4 auto does 28mpg as well Quote Link to comment Share on other sites More sharing options...
Blippie Posted November 9, 2007 Share Posted November 9, 2007 The FBH is more of a winding up "tick-tick-tick" rather than a whining. Does the noise start when the igiition is in position II or just when the engine is started? Cheers Blippie Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted December 4, 2007 Author Share Posted December 4, 2007 It seems to start about a minute after the engine is started. I haven't tried just leaving the ignition on to see if it starts before the engine. Once started it only lasts about 30 seconds even if you stop the car and switch everything off as soon as it starts. Quote Link to comment Share on other sites More sharing options...
Blippie Posted December 6, 2007 Share Posted December 6, 2007 Like a fuel pump or ABS pump priming? ?? Quote Link to comment Share on other sites More sharing options...
Marc1187 Posted December 6, 2007 Share Posted December 6, 2007 Sounds perfectly normal to me, FBH noise, they generally do only make the noise for a few seconds while the burner is starting up, not all the time it is running. I think there was a tech bulletin about it, something to do with the exhaust of the FBH, will try to look at work tomorow. You may also notice smoke coming from the nsf corner of the bumper if stood still or stop the engine just after the FBH has started, i've seen a few people worried that the car is on fire when it does it and they havent a clue what it is! Quote Link to comment Share on other sites More sharing options...
Snaponbear Posted December 6, 2007 Share Posted December 6, 2007 I have a Freelander TD4 SE auto 04 reg with 24k miles on the clock. Some mornings when I drive off there is a noise like a whining noise (not too loud) which lasts about 15 seconds as if something is pumping up or being pressurised. Occasionally during the day it might happen again when pulling away. If I stop the car whilst this is happening it makes no difference. Any suggestions what this might be?Thanks Dennis I had a an irritating whining noise in my Series III although it used to go on for much longer than 15 seconds. Funny thing though, it stopped after I bought The Dragon a car of her own. Worked for me! Cheers, Bob. Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted December 6, 2007 Author Share Posted December 6, 2007 Sounds perfectly normal to me, FBH noise, they generally do only make the noise for a few seconds while the burner is starting up, not all the time it is running. I think there was a tech bulletin about it, something to do with the exhaust of the FBH, will try to look at work tomorow.You may also notice smoke coming from the nsf corner of the bumper if stood still or stop the engine just after the FBH has started, i've seen a few people worried that the car is on fire when it does it and they havent a clue what it is! Yes, I think it must be the FBH, I got the car in April and it only started making the noise when the weather got colder. I have also seen the smoke from the near side front if I stop in the dark just after I have got the engine going. All looks a bit scary! Thanks Dennis Quote Link to comment Share on other sites More sharing options...
