Posted
Hi All,
I got a chance to get some cheap HD shocks for my Disco 1, these hopefully will do until I can convince the misses OMU is the way to go. Only 10 quid a throw.
Does the below if seem right to you, I am just a bit worried that the stroke is not long enough.......
Collapsed (max)* Extended Stroke Mounting
front 330mm 540mm 210mm pin/pin
rear353mm 565mm 212mm eye/pin
Thanks,
Neil
Posted
Does anyone know if 21cm movement on a disco shock is good or not?
Cheers,
Neil
Good or bad is hard to answer but it is about right for a stf. shock...
Certainly for offroaading you could add about 2" travel to that without causing any major issues ( just add some rear relocation cones ).
And with a change of mountings you should easily add another 3" travel to that but for a road car that goes offroad then 21cm is just what LR reckoned is good enough.
David
