Posted
I would say Yes simply because it has to continue the structural integratity of the bulkhead & cos it is part of the load bearing area for the front door hinges.
Posted
How else were you going to hold them on? Superglue?
close i was planning on using super strong aircraft adhesive
if its good enough to hold aircraft together then a small bulkhead patch should cause it no problems!
Posted
I'd weld them in philbert, and do the job properly.
Mo
i will do the job properly i'll fit a new bulkhead when i have time.
what im asking is if i bond the repair panels on will it fail or pass its mot?
Posted
Thanks all
i totally agree with welding them on
but will bond them and hope for a blind mot man :blink:
cheers
Posted
The welding is so easy I don't see why bother with bonding - by the time you've cut the things to make a half decent job, you've done nine tenths of the work and the welding bit is ten minutes a side, and there's no waiting for anything to cure.
Though if you don't have any welding gear, that might be a good reason not to, I suppose...
PS where do I get this stuff that's so strong it's as strong as welding? There are sometimes good reasons not to weld something - usually to do with heat or difficulty in getting a decent electrical contact - or, more mundane reason, when it's not metal you're dealing with! ... in these cases some serious bonding would be a good thing!
Posted
bond it on then use some filler around the edges and use a pencil end to dab the filler to make it look like weld and paint over.....
well that would be one way of doing it
