Les Henson Posted October 27, 2007 Share Posted October 27, 2007 Got round to starting work on the 300TDi engine I got for £50 tonight. Grubby thing innit! Anyway - it has a throttle sensor fitted - which I won't be using. Can I remove it and still use the cable mechanism and will it's removal/non use affect the pump in any way? Thanks. Les. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted October 27, 2007 Share Posted October 27, 2007 Yep you can remove the sensor (for the EGR originally) and still use the throttle linkage. IIRC just undo the three bolts holding it on and it will lift off. HTH Pete. Quote Link to comment Share on other sites More sharing options...
pinny Posted October 27, 2007 Share Posted October 27, 2007 as said remove 3 bolts and it will lift off Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 27, 2007 Author Share Posted October 27, 2007 Lovely, thanks chaps! Les. Quote Link to comment Share on other sites More sharing options...
