Guest diesel_jim Posted November 6, 2005 Share Posted November 6, 2005 I will, sometime in the future, be sticking an autobox into my90, i was wondering if anyone on here has a 50th anniversary or a NAS auto 90, could measure where the brake pedal comes down through the bulkhead. I'm thinking that a) the factory auto's have a *special* bulkhead with differently spaced holes for the brake pedal to stick through, or B) they just have the clutch pedal holes blanked off, and the brake pedal (and servo etc) are all in the "normal" place (albiet with a bigger pedal on). TIA. Jamie Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 6, 2005 Share Posted November 6, 2005 Jamie, I decided to keep all three pedals so this didn't apply to me, however, the only differance is you remove the clutch pedal and master cylinder, blank off the hole and then weld a larger footplate onto the existing brake pedal assembley. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 6, 2005 Share Posted November 6, 2005 Cheers Will. so, what do you use the redundant clutch pedal for? Quote Link to comment Share on other sites More sharing options...
western Posted November 6, 2005 Share Posted November 6, 2005 Cheers Will.so, what do you use the redundant clutch pedal for? nothing it's removed and the hole blanked off Quote Link to comment Share on other sites More sharing options...
woodrow Posted November 6, 2005 Share Posted November 6, 2005 I will, sometime in the future, be sticking an autobox into my90, i was wondering if anyone on here has a 50th anniversary or a NAS auto 90, could measure where the brake pedal comes down through the bulkhead.I'm thinking that a) the factory auto's have a *special* bulkhead with differently spaced holes for the brake pedal to stick through, or B) they just have the clutch pedal holes blanked off, and the brake pedal (and servo etc) are all in the "normal" place (albiet with a bigger pedal on). TIA. Jamie Can do you photos of a 50th and an Ashcroft TD5 auto if it helps, but they're both in the normal place. Do you remember ages ago I had some 1 ton rims and tyres off you? That 100" I was in is auto but with the steering column moved over slightly into the space left from the master cylinder. Makes a nicer driveing position. Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 7, 2005 Share Posted November 7, 2005 Cheers Will.so, what do you use the redundant clutch pedal for? Ahh, that'll be for additional drum brakes for the front (and soon to be rear) 8274s. I'm going to lengthen and narrow the drums at the same time. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 7, 2005 Share Posted November 7, 2005 Can do you photos of a 50th and an Ashcroft TD5 auto if it helps, but they're both in the normal place. Hi Woodrow. The fact that the 50th is in the "normal" place answers my question, thanks. i want to keep as much of my 90 as "factory" as i can (yeah, like a 2.8, auto, SD external cage, mach5's etc etc are all factory... but you know what i mean! ) Quote Link to comment Share on other sites More sharing options...
nas90 Posted November 18, 2005 Share Posted November 18, 2005 When I changed to 4 speed auto on the NAS I just removed the clutch pedal. Brake pedal remained the same. Large auto pedal not necessary and being left hooker the left hand cabin space is smaller than right hand since the gearbox is not centrally placed. Quote Link to comment Share on other sites More sharing options...
