nickm Posted November 1, 2007 Posted November 1, 2007 Noticed on my landy that the top of the drivers side front wheel points in towards the engine a bit does this sound astho I've bent sommit or could it just be wheel bearing's (not yet checked them) Quote
nickm Posted November 1, 2007 Author Posted November 1, 2007 cheers will check bearing over the weekend ta Quote
DaveSIIA Posted November 1, 2007 Posted November 1, 2007 Passenger side front on my 110 was doing the same earlier this week. Wheel bearings fine, swivel bearings seemed ok. Found it to be the lower swivel bearing - got someone to wind the steering from lock to lock and spotted odd movement at the ball. Roller cage had broken and the rollers were doing their own thing. If yours has gone the same, then just over £15 for bearings, seals, gaskets, grease, etc and ~3 hours to strip, replace and set up. Quote
