Hybrid_From_Hell Posted November 7, 2005 Share Posted November 7, 2005 The arches on the back of the 90 have been er..."Trimmed" a lot !. I no longer have the flange that runs around the wheel arch lip (actaully quite of lot of this has ben cut off too ), so the arch is now only properly "Clipped" on the 2 sides, the top is, weell, theres nothing really there, the arch (ali) and the arch (rubber) both trimmed hard back.... My plan is too glue these on, and then use the few clips there are as well.... What to use is the Question ? I have thought of either the stuff they use for putting in windscreens on cars, oe maybe silicone sealer ?...Jon W mentioned something called "Tigergrip" but can't find that ? In todays wonderful Hi tech world what a good "Glue" / "Stuff" to glue these on with, basically I expect whatever it is to "be a one off" and I do not expect to have to remove them again, in fact if I do it will be due to damage, so I would expect the arch to be either KIA or killed removbing it !! Ideas of whats out there then ? Nige Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 7, 2005 Share Posted November 7, 2005 Nige, I'd go for a contact adhesive. Its rubber based so has a bit of flex but it won't let go easily if you use it properly. The only problem is you need to get the position right first time, once its made contact you can't reposition it. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 7, 2005 Share Posted November 7, 2005 Tiger grip is good but you end up wearing more of it on you than you get on the panel Uncle Haroldite after a good clean with thinners or better still rivet the buggers on? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 7, 2005 Share Posted November 7, 2005 Sikaflex may be what you want, it remains semi flexible when it sets and sticks like sh!t to a blanket. used a lot in marine environments so it should be up to the job. Luke Quote Link to comment Share on other sites More sharing options...
Lara Posted November 7, 2005 Share Posted November 7, 2005 Agree with Luke, Sikaflex, Terroson, Tec7 etc is ideal Lara. Quote Link to comment Share on other sites More sharing options...
MogLite Posted November 7, 2005 Share Posted November 7, 2005 Yeah Sikaflex is what you need. Looks and acts like silicon, but is a structural adhesive. About £10 a tube. Its used in the building of Ibex's FWIW. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 7, 2005 Author Share Posted November 7, 2005 where / who stocks this stuff ? Nige Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 7, 2005 Share Posted November 7, 2005 chandleries, but there's probably not many of them near you..... just googled it and there's quite a few online chandleries that stock it. Luke Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted November 7, 2005 Share Posted November 7, 2005 I agree - Sikaflex is the stuff to use. Alternatives are Carbond & Tiger Seal. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 7, 2005 Share Posted November 7, 2005 I don' know if it is the same stuff as some of those products mentioned above but whatever they use to stick bonded windscreens in is incredibly strong stuff! Quote Link to comment Share on other sites More sharing options...
white90 Posted November 7, 2005 Share Posted November 7, 2005 Motor factors around here from Brown Brothers in Exeter Sikaflex224 IIRC or Tiger seal same properties. Brown Brothers Unit 1, Craven Court, Canada Rd, Byfleet, West Byfleet, Surrey KT14 7JL Tel: 01932 352756 Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted November 7, 2005 Share Posted November 7, 2005 What about No More Nails? Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 7, 2005 Share Posted November 7, 2005 Nige, I'd go for a contact adhesive. Did anyone see the Scrapheap challenge when about an hour to go the 'expert' used contact adhesive to stick a truck inner tube to their ice machine. Half way round applying it inner tube goes POP!! Classic- the looks on the other members of the team. Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted November 7, 2005 Share Posted November 7, 2005 Steve I did and it was very funny what a waste of time... Nigel how about not cutting too much off leaving them flapping wildly? or go for the rubber strip style arches and bin the Defender ones? Quote Link to comment Share on other sites More sharing options...
ripley Posted November 8, 2005 Share Posted November 8, 2005 nige, i'll get you some in if you want, i normal keep a box at work, just shout if you still need some. regards graham Quote Link to comment Share on other sites More sharing options...
MarkieB Posted November 8, 2005 Share Posted November 8, 2005 Just found a link to bigger eyebrows for the muddy system involves rivets on a top edge added to the eyebrow Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 8, 2005 Share Posted November 8, 2005 What about No More Nails? What about just nails? hat/coat/slam..... Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 8, 2005 Share Posted November 8, 2005 What about No More Nails? Now how come you get away with saying that?? I got told to F off when i suggested it!!! :-) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 8, 2005 Share Posted November 8, 2005 I could tell you where to stick things Nige!! Les. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 8, 2005 Share Posted November 8, 2005 i've heard he already knows Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted November 8, 2005 Share Posted November 8, 2005 <JOKE> Irish terrorists have reportedly injured 100 people in their first ever "no more nails" bombings, the Irish Times said today. Sorry Pauls post made me do it! <blush getting coat from Nige and leaving as quietly as possible for me> Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 8, 2005 Share Posted November 8, 2005 Next thing we'll get is a story about how the cat got stuck to the bonnet Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 8, 2005 Share Posted November 8, 2005 Next thing we'll get is a story about how the cat got stuck to the bonnet is that the one where he uses petrol to loosen the no nails in an attempt to free said moggie .... Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 8, 2005 Share Posted November 8, 2005 Hahahahahahaha how about Gripfill Nige??? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 8, 2005 Author Share Posted November 8, 2005 How that bent handbrake disc I gave you that Tonk made ? Nige Quote Link to comment Share on other sites More sharing options...
