Posted
hi
i was given a bobtailed ranger and the head gaskets gone and the transfer box has given in the wiring is a bit simple the dampers are slightly gone
now i have the choice of buying an old disco and doing it up as a pit car OR trying to repair the rangie
if i scrap the ranger is there any parts worth keeping/restoring e.g. axles ?(are good) engine could rebuild
any advice would be grateful
watson
Posted
Forget the Disco unless there are any parts you can put on the Rangy - I mean, have you seen the disco forum? they have flock wallpaper for gawds sake.
Les. :P
as les says use the bits of both to make one good one, diesel into rangie, and as for flok wallpaper I have non just bits of rusty disco
Russ
Posted
Josh,
You should buy that 4dr RRC bob I showed you pics of and keep the old one for bits :P go on you know you want to. Rollbar, guarded up underneath and little Dirt Devils perfect for what you want
Steveb
Posted
Josh,
Steveb
i very tempted
thanks for all the feed back
