Astro_Al Posted December 5, 2005 Share Posted December 5, 2005 Right, dunno if this is going to work... Here are 3 pics of the removeable crossmember from Designa Chassis. the two little brackets get welded under the main chassis rails, then the crossmember just bolts up to these. Frankly, nowadays I'd just make my own, but I bought it a good few years ago when I couldn't weld etc... You live and learn... I might alter it (or make my own) to bolt to the inside of the chassis rails (if there is room) so that I on't have so much carp hanging down underneath. B) Oh.... carp. I can't get the images I have put in my gallery to load up on this page. Just check out the gallery: http://forums.lr4x4.com/index.php?act=modu..._album&album=25 . Hope that gives you some ideas... Al. Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted December 5, 2005 Share Posted December 5, 2005 Reckon you both weigh about the same if you take into account Tonks head! (ok yes i know i will be in trouble for that one !!!!) Quote Link to comment Share on other sites More sharing options...
minivin Posted December 5, 2005 Share Posted December 5, 2005 Right, dunno if this is going to work... Here are 3 pics of the removeable crossmember from Designa Chassis. the two little brackets get welded under the main chassis rails, then the crossmember just bolts up to these. Frankly, nowadays I'd just make my own, but I bought it a good few years ago when I couldn't weld etc... You live and learn...Hope that gives you some ideas... Al. looks military-based to me as it looks the same as whats under my 109 FFR, worth visiting a ex-MIL sales person and crawling under a vehicle and un bolting one, fabricating the brackets and saving a few pennies Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 looks like a gearbox mounting xmember to me????????? i was referrin to the bellhousing xmember, same sort of thing though, think mine will be slightly better made (read heavier ) Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted December 6, 2005 Share Posted December 6, 2005 looks like a gearbox mounting xmember to me????????? i was referrin to the bellhousing xmember, same sort of thing though, think mine will be slightly better made (read heavier ) Yeah, I thought we knew that??? It was just to see how it could be done - a crossmember is a crossmember! I agree it could be beefier, I may not use it in the end and just make my own. I think they base the design (i.e. copy) the removeable military ones, so yeah, it should look the same. Al. Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 6, 2005 Author Share Posted December 6, 2005 i think mine will have 15mm thick mounts with rollcage tube as the member Quote Link to comment Share on other sites More sharing options...
Marc Posted December 11, 2005 Share Posted December 11, 2005 yes i have replaced bot front bellhousing cross member and gearbox member as they both got smashed i will take some photos when ive cleaned it, as i have just shattered the hand brake drum to bits on a stump so i will add another cross member just behind the drum with a bask bar underneath. marc Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 12, 2005 Author Share Posted December 12, 2005 would be good . i'm just about done on me rollcage and i'm about to have some time off Quote Link to comment Share on other sites More sharing options...
