Posted
Hi,
Ignition light came on a week or so ago, fitted external regulator unit from ebay, now there is a drain on the bat.....
Any ideas...?
cheers
Dave
Posted
fitted external regulator instead of, or as well as?
if you've got charging problems, and the alternator is draining the battery with everything switched off, it's likely a diode has failed in the rectifier.
Posted
Hi Guys,
I have just replaced the one that bolts on the back of the alternator, didn't have a propblem with the bat going flat before just ign light stayed on when running, this draining the bat fault appeared after fitting the new unit...?
Still need to go for a new alt or can i replace the diode....?
cheers
Dave... :(
Posted
rekab69 When you have everything turned off, and the engine has been allowed to cool completely - try putting your hand around the alternator, if it feels warm then chances are it’s permanently energized. This would explain the current draw because it means the alternator is pulling a small amount of power to energize itself, and because its not rotating and generating power it basically turns into a little heater!
I've seen this many times before when people have used replacement regulators that are maybe not exactly the same. Usually it’s seen when people fit advanced charging regulators which work in a slightly different manor.
If you need a replacement alternator send me a PM and I’ll give you the different options I'm able to supply, with forum discount of course! :)
Thanks,
Matt
