Removing Front Output Flange on Transfer Box?
I need to remove the flange on the front output of the transfer box to replace the captive propshaft bolts.
Can anyone give me some tips before doing the job?
- How to hold the flange whilst undoing the tight centre nut? - Unless anyone has any better ideas I was think of using a length of bar with a couple of holes drilled in to slip over a couple of the prop shaft bolts.
- Also my assumption is that the centre nut is the standard thread ie anticlockwise to undo.
Presumably once the nut is undone the flange slips off easily?? - no pullers !! ??
Thanks
Nick
Lock the centre diff, handbrake on, chock wheels - you won't have any problems then. The nut is a standard RH thread. You may find the flange is a little tight but I've never had to resort to a puller.
Matt
