dan9090 Posted November 3, 2007 Share Posted November 3, 2007 hello again, you may have seen my other current post on overheating from last night/this morning.... gone to continue my investigation in the engine bay and as usual there's another problem .... may bonnet release catch wont work its got a inch or so movement in it but its not releasing the catch, whats the solution folks? sounds like another weekend outside, the missus is going to be chuffed Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted November 3, 2007 Share Posted November 3, 2007 I had one that was stuck in same position, the striker (the large bolt with shaped end that holds the bonnet in second position had become a bit bent and the actual mechanism was sticking in the closed position. I used a screwdriver to move striker, and the greased and WDd the mechanism which freed it all up. Might need to get the plastic grille off to allow access to the underside of the mechanism and get bonnet open in the first place... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 3, 2007 Share Posted November 3, 2007 before you go taking things apart, get someone to stand on the bumper and push the bonnet down, whilst you try pulling the lever again. Quote Link to comment Share on other sites More sharing options...
disco tony Posted November 3, 2007 Share Posted November 3, 2007 you can also pull the bonnet release cable from behind the grill. It is a bit tight, but put some fingers between the top grill openings just to the left of centre, fingertips pointing up, have a fiddle, you should feel the cable, a quick tug and hopefully, "hey-presto". Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 3, 2007 Share Posted November 3, 2007 a quick tug and hopefully, "hey-presto". B) Quote Link to comment Share on other sites More sharing options...
alantd Posted November 4, 2007 Share Posted November 4, 2007 B) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 4, 2007 Share Posted November 4, 2007 The bonnet catch mechanism does tend to sieze-up especially if you go off road at all. Pulling on the bonnet catch strecteches the cable, but it is adjustable. If you remove the grill you can operate the short lever that the end of the cable attaches to and can then open the bonnet. The mechanism is held to the slam panel by two 10mm bolts, the return spring, and the cable end. It's easy to remove, free up, lubricate, and re-fit. Check, clean, and lubricate the bonnet pin (on the bonnet itself), as well. If you want to replace the cable they are only about £8 for a gen item and are fairly easy to replace. Les. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 7, 2007 Share Posted November 7, 2007 You cant get yours open, and now i cant get mine closed. When i look in the hole where the pin on the bonnet is supposed to slot into, there's a piece of metal shaped a bit like a half moon, protruding into the space where the pin is meant to go. I have pushed it back with screw driver but it just returns to block the hole. Any thoughts? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 7, 2007 Share Posted November 7, 2007 You cant get yours open, and now i cant get mine closed. When i look in the hole where the pin on the bonnet is supposed to slot into, there's a piece of metal shaped a bit like a half moon, protruding into the space where the pin is meant to go. I have pushed it back with screw driver but it just returns to block the hole.Any thoughts? That'd be the catch! it's supposed to be there! the pin is shaped like a cone, to push the catch back, then there's a lip that it springs back over, holding the bonnet closed. I'd reckon your pin isn't that cone shaped anymore and isn't pushing the catch back. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 7, 2007 Share Posted November 7, 2007 I will take a couple of pics and let you see. Looks not too bad to me but then again i am probably wrong. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 7, 2007 Share Posted November 7, 2007 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 7, 2007 Share Posted November 7, 2007 When you pull the bonnet release the plate should move out of the way to allow the pin to pop up. Get someone to pull on the release and see if it moves at all. If not the inner cable has snapped, the inner cable has slipped inside the little clamp that secures it to the mechanism, or the release mechanism is siezed. Les. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 7, 2007 Share Posted November 7, 2007 So the plate thats visable in the hole...................shouldn't that be back a bit? It slides to the left when moved with screw driver. How can i sort it? Cheers DC Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted November 7, 2007 Share Posted November 7, 2007 The bit that is across the hole should slide out of the way as the cone shaped pin on the bonnet pushes down onto it and then snap back across the whole to hold the bonnet down. I would suggest a liberal aplication of lubricant to both the pin and catch and try it again. Pete. Quote Link to comment Share on other sites More sharing options...
nas90 Posted November 7, 2007 Share Posted November 7, 2007 The bit that is across the hole should slide out of the way as the cone shaped pin on the bonnet pushes down onto it and then snap back across the whole to hold the bonnet down. I would suggest a liberal aplication of lubricant to both the pin and catch and try it again.Pete. Looks like a good wash with wd40 and stiff paint brush followed by some good old thick grease will fix that one. They do need constant cleaning and lubricating, but then what doesn't on a Defender Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 7, 2007 Share Posted November 7, 2007 Cheers guys, ran out of WD40 so will get more tomorrow and soak the barsteward. Will also pack it with a bit of grease. DC Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 7, 2007 Share Posted November 7, 2007 Light oil frequently if you play in the mud and grease if it's a road vehicle. Grease will absorb grit etc and sieze-up quicker. Les. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 8, 2007 Share Posted November 8, 2007 Lightly oil it is then. Just hope it frees up some. Is there something that should help the plate slide back as the pin goes in? I have a feeling it might not just be seizing. DC Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 8, 2007 Share Posted November 8, 2007 The tapered end of the pin pushes the plate out of the way, which then snaps back with assistance from a quite strong spring. If you push the plate out of the way with a screwdriver it should move back when you stop pressing. Les. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 8, 2007 Share Posted November 8, 2007 It does, so lots of WD40 then it is...................... Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 10, 2007 Share Posted November 10, 2007 THANK YOU WIFE !!! Ok hands up time, by using womens observations, you know what i mean, when they can get a wiff somits not right from 5 miles away without even seeing anything. The mrs comes down to help me today as i removed all the grill, the actual pin and spring cleaned it all up, took off the bottom half and made sure everything was ok.............................put back on the pin with a few extra washers to secure it a bit better then tried again.............................still it would not close. So down comes the wife.........................................any luck? Nope i'm stumped!!! Then she says, why are these poking out from the battery? I secured the battery a bit better in place some 5 or 6 days ago , but the rods that where being used stood a bit tall. Yes you guessed it........................................it was these that was preventing the bonnet from being closed. So hack saw came out.Made them a bit shorter and low and behold.............................bonnet closed. Couldn't stop laughing for about ten minutes. Quote Link to comment Share on other sites More sharing options...
