white90 Posted August 10, 2005 Share Posted August 10, 2005 I've fitted a Hella Intermittent Wiper Unit on my 110. It has a rotary switch/potentiometer (like an old-fashioned radio off/on-volume switch) Here's a piccy - "The intermittent switch automatically stops/starts the windscreen wiper at regular intervals, 2-20 times per minute. For windscreen and rear window wipers, for positive and negative-earth vehicles. With installation material." Intermittent wipe control unit, 5-pin, part no's - 12V = 5WA 001 871-041 24V = 5WA 001 871-051 * (Special order only) I've installed it into the 3-switch panel on the lower right hand side of the dash. I made a new panel to take the rotary control in the middle, with the Hazard Warning and Heated Rear Window switches either side of it. I'm in the process of fitting the 2002 dash which has the new type Hazard Warning and Heated Rear Window switches, I intend to fit the intermittent control into the headlamp levelling switch position. It cost me £12.99 in 1990. Paul. --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Also available from Simonb is a relay to fit behind the switch panel that gives intermittent rear wipe. Link to comment Share on other sites More sharing options...
western Posted June 1, 2011 Share Posted June 1, 2011 http://forums.lr4x4.com/index.php?showtopic=68514 more detail doing same job but using genuine LR parts instead of aftermarket parts. Link to comment Share on other sites More sharing options...
