Porny Posted November 4, 2007 Posted November 4, 2007 As in topicRegards Ray Yes.... One off a 90 will be a straight swap.... One off a 110 (will be a later none Salisbury axle) - will also fit, but you will need to change the spring mounts for the ones off you current axle, and you will need a custom length prop (although a front one off a 200Tdi Defender isn't too far off). For both axles - you will ideally need late spec rear dampers - as the mount on the axle differs from that of your 200Tdi. Ian Quote
BogMonster Posted November 4, 2007 Posted November 4, 2007 oops beaten to it and wrong on one bit too. I'll shut up Quote
bombx3 Posted November 4, 2007 Author Posted November 4, 2007 Yes....One off a 90 will be a straight swap.... One off a 110 (will be a later none Salisbury axle) - will also fit, but you will need to change the spring mounts for the ones off you current axle, and you will need a custom length prop (although a front one off a 200Tdi Defender isn't too far off). For both axles - you will ideally need late spec rear dampers - as the mount on the axle differs from that of your 200Tdi. Ian Thanks for the info trying to up grade my knackered axle for disc brakes ,24 splines and 4 pin diff ,i was told disco axles fit is that true also what is the difference in shock mountings on the 04 axle compared to my 200tdi Quote
Porny Posted November 4, 2007 Posted November 4, 2007 Thanks for the info trying to up grade my knackered axle for disc brakes ,24 splines and 4 pin diff ,i was told disco axles fit is that true also what is the difference in shock mountings on the 04 axle compared to my 200tdi A disco axle will also fit (straight swap) - unless you use one off a 300Tdi.... If you use a 300Tdi jobbie, you will need to change the diff output flange for a four bolt jobbie (as a 300Tdi Disco uses a 3 bolt arangement with a rubber doughnut) - you should just be able to swap the flange for the one off your current rear diff. The rear damper mount.... instead of having a flat mounting (as per your 200), the axle also incorporates a cup for the rubber bush (bushes are also a slightly different shape). In saying that, if you play around with the rubbers (and washers) you should be able to re-use your dampers (but won't be 100% ideal) Ian Quote
bombx3 Posted November 4, 2007 Author Posted November 4, 2007 if a defender 90 axle had abs how would that effect the change on to my 200tdi Quote
GBMUD Posted November 5, 2007 Posted November 5, 2007 You would have to cut off the sensor wires. Chris Quote
SteveG Posted November 5, 2007 Posted November 5, 2007 The rear damper mount.... instead of having a flat mounting (as per your 200), the axle also incorporates a cup for the rubber bush (bushes are also a slightly different shape). In saying that, if you play around with the rubbers (and washers) you should be able to re-use your dampers (but won't be 100% ideal) Just to add that it takes about 20 mins to drill out spot welds and chisel off these cups. Cheers Steve Quote
