dred90 Posted November 7, 2005 Share Posted November 7, 2005 I've just bought an N.A.S. front cage for the 90 and now want to attach some spots to the top of the cage, there are no brackets welded onto the cage, so i was wondering what the best way would be to attach the lights to the cage without welding brackets on? Is there any kind of tube clamp or bracket you can buy and if so where can i get them from?? cheers Ed B Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 8, 2005 Share Posted November 8, 2005 I've just bought an N.A.S. front cage for the 90 and now want to attach some spots to the top of the cage, there are no brackets welded onto the cage, so i was wondering what the best way would be to attach the lights to the cage without welding brackets on? Is there any kind of tube clamp or bracket you can buy and if so where can i get them from??cheers Ed B Not used them but here are some options: http://www.evansuk.ltd.uk/rollcageextras.html Quote Link to comment Share on other sites More sharing options...
rod Posted November 8, 2005 Share Posted November 8, 2005 Exhaust clamps? Have used them on mine.....means if i smack a light off road the light just twists rather that breaks/mangles the welded on tab. I run 4 x 5x7 KCs on mine and you cant see them behind the lights anyway. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 8, 2005 Share Posted November 8, 2005 You can also use jubilee clips, it just depends on the shape of your lamps bracket. Mo Quote Link to comment Share on other sites More sharing options...
woodrow Posted November 8, 2005 Share Posted November 8, 2005 I've just bought an N.A.S. front cage for the 90 and now want to attach some spots to the top of the cage, there are no brackets welded onto the cage, so i was wondering what the best way would be to attach the lights to the cage without welding brackets on? Is there any kind of tube clamp or bracket you can buy and if so where can i get them from??cheers Ed B Its not a NAS one then. All genuine ones have the tabs. In the past I've used jubilee clips on my own, if you get it right when you hit them they just twist round rather than smash the light to bits. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 8, 2005 Share Posted November 8, 2005 I've got tabs but I've seen 52mm exhaust clamps used equally effectively in the past. To slightly threadjack, I want to replace the lamps I used to have above the windscreen. They're below the cage to protect them but I need a unit that doesn't illuminate the windscreen and cab, ie doesn't shine backwards at all. Any pics/suggestions? JB Quote Link to comment Share on other sites More sharing options...
dred90 Posted November 9, 2005 Author Share Posted November 9, 2005 Exhaust clamps?Have used them on mine.....means if i smack a light off road the light just twists rather that breaks/mangles the welded on tab. I run 4 x 5x7 KCs on mine and you cant see them behind the lights anyway. i assume we're talking this type of thing Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 9, 2005 Share Posted November 9, 2005 Not quite - design wise you're spot on but mine just aren't as bling... Quote Link to comment Share on other sites More sharing options...
rod Posted November 9, 2005 Share Posted November 9, 2005 Turbocharger How about a bit of electrical tape on the bottom to stop them shining in the cab, thats what i did with mine....stops them lighting the dashboard and bonnet to much. Mine are under covers most of the time exept when offroading so the look doesnt matter to much. Rod Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 9, 2005 Share Posted November 9, 2005 Well, obviously using them on the road is illegal, but for the many offroad miles I do where roof lights would be handy... I've tried insulating tape in the past but even several layers don't seem to block out the light. I was hoping for someone to produce an ad for a rectangular lamp that completely surrounds the glass lens Quote Link to comment Share on other sites More sharing options...
DiscoDino Posted November 9, 2005 Share Posted November 9, 2005 All genuine NAS roll bars have 4 tabs on the front A bar top bar... Why not get an ARB bumper antanae bolt on thingy...https://www.expeditionexchange.com/arb/DSC00022340.jpg Quote Link to comment Share on other sites More sharing options...
dred90 Posted November 9, 2005 Author Share Posted November 9, 2005 Thanks for all the advice guys, I'm sure I'll be able to cook up something now!! Quote Link to comment Share on other sites More sharing options...
