TripTrick Posted December 9, 2007 Share Posted December 9, 2007 I have a complete but buggered S3 gearbox and xfer case for u. Maybe u can build one box from the two. I stripped the first gear so maybe the shafts are bent. Otherwise I will dump it at Rob Leimer's. Thanks Gareth, Thats good of you thanks, I will take it. Sent you a PM. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted December 9, 2007 Share Posted December 9, 2007 Bill tell us more about putting a S3 layshaft into a 2a box please. This conversion addresses the problem of layshaft flex and fatigue breakage in the second gear area common on series1,2 and 3 gearboxes and involves grinding off 1st and reverse gear teeth from a scrap series 3 cluster gear and grinding or milling the four coarse splines that accept the series 2 press on 1st gear pinion. the splining obviosely needs to be done at an engineering works or precision grinders shop. Bill Quote Link to comment Share on other sites More sharing options...
