Roy Batty Posted November 13, 2007 Share Posted November 13, 2007 Howdy Folks; What is the story on Bearmach parts - how do they fare with B**tPart , Allmakes and genuine LR Cheers ya Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 13, 2007 Share Posted November 13, 2007 I've had no problems at all with the stuff i've had from them. rubber bushes seem OK (look almost like genuine ones). little things like gaskets and pipe clips are much cheaper. if they don't have bearmachs' "own" brand items, they get genuine parts in, and if you're happy to wait a few days you can get them a bit cheaper than over the genuine dealer counter. Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 Howdy Diesel Jim: I usually order all my parts - usually from UK - so waiting is the game I always play I only know AllMakes and B**Tparts - and the latter I do not care for - besides genuine LR - I will order genuine but for now my lift pump needs attention right quick primarily I use B99- B75 - B50 in winter - so diaphragm material is important - I will like to think Genuine is supplying Viton or something as rugged to stand up to ULSD - not shrink and dry out Cheers ya Quote Link to comment Share on other sites More sharing options...
western Posted November 13, 2007 Share Posted November 13, 2007 not had any problem with Bearmach parts. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 13, 2007 Share Posted November 13, 2007 I buy the vast majority of my parts from Bearmach, but there are things I would only buy genuine from them, such as wheel cylinders, brake and clutch master cylinders, clutch slave cylinders, and water pumps. Their 300TDi timing belt kits are far superior to the genuine items, and as Jim says, rubber bushes are both cheap and comparable to genuine. They are supposed to be having a big shake-up over quality of some of their parts, so we will see. Even genuine stuff from them is cheap though, so no big sting in the tail if you prefer gen parts. Les. Quote Link to comment Share on other sites More sharing options...
simonr Posted November 13, 2007 Share Posted November 13, 2007 Bearmach supply both patterned and 'genuine' OEM parts. They are both pretty reasonable value - and usually up for a bit of haggling! You need to be a bit selective over which you use in what situation though. As a rule of thumb, I use genuine for anything which turns, seals or is safety critical. Anything else can be patterned. Si Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 Howdy Lee: you speak of Bearmach having a shake up or Genuine LR- over parts quality ? And hopefully not as bad as B**tPart. I have a new old stock water pump for the 200Tdi - and I am thinking it may be B**part - should get a genuine by spring are there any good discount LR parts suppliers that will post to USA - that you might know? Cheers ya: Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 13, 2007 Share Posted November 13, 2007 LEE ? I think all the major L/R parts suppliers will post abroad. LES! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 13, 2007 Share Posted November 13, 2007 We deal a lot with BM at work and always get the OEM branded parts i.e. Wipac/Lucas/Coopers/Lockheed etc etc best combination of decent quality and decent price IMHO. Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 Howdy Les: Sorry mate - haven't had my tea yet So far I have yet to find a genuine LR water pump on the 4 sites I have visited - is there a Direct LR parts online order place you might direct me to - Water pump I will like Genuine LR - here the internet has become huge for direct parts - Nissan for example is usually very costly - yet I order parts on internet and they come direct from Dealer at 40% savings helps now especially now that the dollar is worth .01$ Cheers ya Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 13, 2007 Share Posted November 13, 2007 Bearmach sell gen water pumps for the 300TDi - I bought one the other day. Les. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 13, 2007 Share Posted November 13, 2007 For years I have been doing the same thing with parts If its a simple to get to or to replacement / maybe a service item I will consider Non Genuine. The more difficult the job is to redo if the part fails, if its a seal, gasket, or other part that = PITA if it fails, and often is a cheap part anyway when gaskets etc - for example the genuine gasket for a 3.9 V8 water pump is very different to the inferior many pattern ones . I will go 'Quality branded' on some items all the time - eg Brake pads, discs, calipers, track rods etc, HS for UJs SKF Timken for bearings etc rather than Bearmach, but for anything really important (and I'll inc oil filters here - one collapsing - and yes I have come across them is goodbye engine) then has to be genuine - and things like springs engine bits gearbox or diff gears, or other key parts. Bearmach stuff can often be genuine, BUT I have found that since LR dropped the prices on older stuff - known as "Classic" sometimes genuine stuff is cheaper than pattern stuff ! - ie RR Coil springs. and you get exatly what you wnat ie the right poundage for the job not a "Gawd knows what special" I would frankly pay more for quality / peace of mind / getting exactly what I want Nige Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 13, 2007 Share Posted November 13, 2007 All the parts I am using to rebuild the 300TDi engine are gen items - even the pistons. I know it costs more, but it would be worse if I had to take the thing apart again just because I wanted to save a few quid. Les. Quote Link to comment Share on other sites More sharing options...
white90 Posted November 13, 2007 Share Posted November 13, 2007 I had a genuine lift pump it lasted 2years so I got a Britpart one I'll let you know how long it lasts, it seemed good quality out of the box Quote Link to comment Share on other sites More sharing options...
jules Posted November 13, 2007 Share Posted November 13, 2007 I have never had problems from Bearmach and there part put two racers through four years of races and several class wins and a challenge truck to a few challenge wins. I have found there service very good but I have good friends within Bearmach so my comments could be biased Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 Howdy mates: Exactly :pay for the Quality - why i want genuine for the water pump - as I am living in the desert sometimes 44º Do you say that Bearmach makes genuine? Ancillaries for me should be of very good quality if not genuine- water pumps always genuine - most things internal - with perhaps exception to rings and valves if there was better quality/performance available with good reputation Cheers: Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 Howdy Jules: I ask opinions - even biased - and check if there is anything negative written about - race proven says alot to me Cheers ya: Quote Link to comment Share on other sites More sharing options...
Roy Batty Posted November 13, 2007 Author Share Posted November 13, 2007 howdy Mates: Just to add - Filters are exclusive- Baldwin -great filters Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 13, 2007 Share Posted November 13, 2007 I've never had any trouble with Bearmach stuff, Les Henson fitten both a Bearmach clutch kit and a Bearmach timing belt kit to my disco, both have been fine... just beware of B**Tpart.... Quote Link to comment Share on other sites More sharing options...
reads90 Posted November 14, 2007 Share Posted November 14, 2007 I have alot of bearmach stuff on my truck and draged them all round aus with no problem at all. I also have alot of their Accessoies and had not problems with them There Bushes are really good too. Beat them on quite a few corrigations Quote Link to comment Share on other sites More sharing options...
jules Posted November 14, 2007 Share Posted November 14, 2007 Howdy Jules:I ask opinions - even biased - and check if there is anything negative written about - race proven says alot to me Cheers ya: I'm not getting dragged into other supplier’s quality as I simply don't know. They are a wholesaler so supply the Retailers and not the General public direct (only through their retail shops) IME if they don't make it they send me GP but there own parts as still a good standard and some are still UK made and they can supply pretty much anything LR you would want there own brand or GP. Talk to the head office (number is on the back of LRO and most of the other mags.) They will be able to answer any other questions you may have. Everything from my RRC LSE has come from Bearmach Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 14, 2007 Share Posted November 14, 2007 Do you say that Bearmach makes genuine? No, but Bearmach do buy in genuine Land Rover stuff and re-sell that alongside the OEM parts and own-brand parts in their range. Some items are only available as Genuine. Quote Link to comment Share on other sites More sharing options...
