Tony_C Posted November 21, 2007 Share Posted November 21, 2007 Hello folks - new to this forum - from north notts I have just started rediscovering my SIII, its been at the bottom of the garden under leaves and branches since i put it there in a small temper after the engine gave up over a year ago when i had even less spare cash than i do now. I have in the shed two dead 2 1/4's and in the process of removing a dead (never run actually) 2.5NAS - i put this in when the last 2 1/4 failed - was smoking for a while then the head gasket went. but this 2.5 has never run whilst i've had it. Is there anywhere i can find out more about the engine types (i have a few manuals but i just wanted to know the major differnces before i try to get one of these running or start searching for another.) I have a 2.5NAS - engine number 12J I know someone with another engine - not sure what it is he says engine number is 18J... I have a SWB SIII on a W plate. Thanks Tony Quote Link to comment Share on other sites More sharing options...
ARAF Posted November 21, 2007 Share Posted November 21, 2007 12J is just noted as a 2495 90/110 diesel. I've not heard of an 18J, but a 19J is a 2495 Turbo diesel, I believe. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 21, 2007 Share Posted November 21, 2007 Tony, Brief history of diesels fitted as standard to series land rovers: bit weak mechanically and a bit underpowered but not too thirsty. A bit more detail but not 100% on when actual change over took place Series 1 2 litre disel 3 bearing which is not really suitable for modern daily use Series 2a and Series 3 (early) 2286 3 bearing engine which was adequate in a lighter rover but would struggle to haul a heavy 109" at greater than 50 mph 2286 5 bearing engine as 3 bearing but a bit more reliable All identifiable by the fuel pump in the same position as the distributer as the petrol engine. 5 bearing engines identifiable by engine number ( can't find the manual ) either 301 or 901 or something That's it for series diesels (though land rover did experiment with direct injection turbos in the 60's) Now, when the 90/110 came out the 5 bearing diesel engine was warmed over with the pump moved to t he front side of the engine running of the new timing belt, capacity was upped to 2.5 litres. Still not powerful but was ok reliable and worth sticking with unless you need the extra power. This is the 12j engine (I think) Later they strapped a turbo on = bad idea - the block wasn't up to it and was an unrelaible engine for many years until the block was redone. This is the 19j I think. 19j being the begining of the serial number The later version of this engine was ok. Then..... the TDI.(200 and 300) Great engine; looked after good for 1/4 million miles. Threre were timing belt issues but these are sortable. after that came the TD5 and the Dcti, both of which I know nothing about other than they have electonics. Longer than I thought. Gottago. G Quote Link to comment Share on other sites More sharing options...
Tony_C Posted November 21, 2007 Author Share Posted November 21, 2007 hanks for the reply Gazzer, any idea what a 18J is ? Tony Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted November 22, 2007 Share Posted November 22, 2007 Badly stamped 19J ??? Engine ID 105xxxxxx Series III petrol 3528cc V8 10Hxxxxxx 90/110 petrol 2286cc 8:1 CR 10Jxxxxxx 90/110 diesel 2286cc 11Gxxxxxx Series III petrol 3528cc V8 (detoxed) 11Hxxxxxx 90/110 petrol 2286cc 8:1 CR (detoxed) 12Gxxxxxx Series III petrol 3528cc V8 (Australia) 12Jxxxxxx 90/110 diesel 2495cc 13Hxxxxxx 90/110 petrol 2286cc 7:1 CR 141xxxxxx Series II petrol 1997cc 146xxxxxx Series II diesel 2052cc 14Gxxxxxx 90/110 petrol 3528cc V8 151xxxxxx Series II petrol 2286cc 156xxxxxx Series II diesel 2052cc 15Gxxxxxx 90/110 petrol 3528cc V8 (detoxed) 19Jxxxxxx 90/110 turbodiesel 2495cc 236xxxxxx Series IIA petrol 2286cc (fitted to 88 inch airportable) 241xxxxxx Series IIA petrol 2286cc 8:1 CR 251xxxxxx Series IIA petrol 2286cc 7:1 CR 252xxxxxx Series IIA petrol 2286cc 7:1 CR 253xxxxxx Series IIA petrol 2286cc 7:1 CR 271xxxxxx Series IIA diesel 2286cc 276xxxxxx Series IIA diesel 2286cc 286xxxxxx Series IIA petrol 2286cc (Forward Control) 300xxxxxx Series IIA petrol 2625cc (Forward Control) 325xxxxxx Series IIB petrol 2286cc (Forward Control) 330xxxxxx Series IIB petrol 2625cc (Forward Control) 335xxxxxx Series IIB diesel 2286cc (Forward Control) 345xxxxxx Series IIA petrol 2625cc 361xxxxxx Series III petrol 2286cc 8:1 CR 5-bearing 364xxxxxx Series III petrol 2286cc 7:1 CR 5-bearing 366xxxxxx Series III diesel 2286cc 5-bearing 895xxxxxx Series III diesel 2286cc 3-bearing (fitted to 88 inch airportable for export) 901xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 902xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 903xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 904xxxxxx Series III petrol 2286cc 7:1 CR 3-bearing 906xxxxxx Series III diesel 2286cc 3-bearing 941xxxxxx Series III petrol 2625cc 951xxxxxx Series III petrol 2286cc 3-bearing (fitted to 88 inch airportable) 956xxxxxx 101FC petrol 3528cc V8 961xxxxxx 101FC petrol 3528cc V8 Quote Link to comment Share on other sites More sharing options...
Tony_C Posted November 22, 2007 Author Share Posted November 22, 2007 Looks like a pukka 18 to me - is it possible its not LR after all? Tony Quote Link to comment Share on other sites More sharing options...
danshepp Posted November 23, 2007 Share Posted November 23, 2007 THE ORIGINAL STAMP UNDER THERE SAYS 12J. I would say someone has tried to restamp that engine at least twice! Quote Link to comment Share on other sites More sharing options...
danshepp Posted November 23, 2007 Share Posted November 23, 2007 sorry, forgot to add : ORIGINAL ENGINE NO,S READ AS FOLLOWS 12J 493*26 can't make out the fourth digit as to badly ground down! someone has done a right job to those numbers ( be careful that engine may have gone missing at some time in its dubious history!) Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 23, 2007 Share Posted November 23, 2007 I'm not going against the theory of 'possibly stolen & re-numbered' at sometime in it's pastt, but the renumbering is very badly done if it was intended to hide something. What I have in mind is the way the Factory dealt with rebuilt gearboxes in Series vehicles. Here they ground the number off it's original location, then added a new one elsewhere. However, perhaps because the factory had nothing to hide, the original numbers can be readable. Mine were, which is why I came to learn about this Factory rebuild & renumber business. British Leyland had their Gold Seal and Silver Seal engines. Did LR have a similar system? As the 12J with turbocharger became a weakness they might well have had a goodly number of engines available for rebuild. Alternatively, weren't LR engines used in London Taxis and Leyland (Sherpa?) vans? Did they have a different numbering scheme? I'm afraid I have no definivative answers, only observations and questions. Nevertheless, HTH. Quote Link to comment Share on other sites More sharing options...
Tony_C Posted November 23, 2007 Author Share Posted November 23, 2007 Looks like i'll leave that one then - thanks for the help guys. (next question where do i find a running 2.5NAS .................) Cheers Tony Quote Link to comment Share on other sites More sharing options...
bazz Posted November 23, 2007 Share Posted November 23, 2007 Hi, i am in the process of overhauling a 12J, just went over and had a look but on that picture it sure doesn't look like a 12J the number seems to be on the other side and the fuel pipe mounting seems to be angled differently with respect to the glow plugs. Why don't you send a picture of the whole engine. Im sure we can figure it out then. greetings Bas Quote Link to comment Share on other sites More sharing options...
Tony_C Posted November 27, 2007 Author Share Posted November 27, 2007 I won't be using this thing - but just t complete the story there should be two pics attached Cheers Tony Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted November 27, 2007 Share Posted November 27, 2007 Is that a 24volt 2.5nad?, that might explain the odd prefix on the engine number. From the pics it looks like it has a belt driven vac pump, original gear driven one in way of the 24v generator? bigger pulleys on crank and waterpump. Oh and a turbo spec block. Quote Link to comment Share on other sites More sharing options...
mrdoiron Posted June 1, 2010 Share Posted June 1, 2010 Badly stamped 19J ??? Engine ID 105xxxxxx Series III petrol 3528cc V8 10Hxxxxxx 90/110 petrol 2286cc 8:1 CR 10Jxxxxxx 90/110 diesel 2286cc 11Gxxxxxx Series III petrol 3528cc V8 (detoxed) 11Hxxxxxx 90/110 petrol 2286cc 8:1 CR (detoxed) 12Gxxxxxx Series III petrol 3528cc V8 (Australia) 12Jxxxxxx 90/110 diesel 2495cc 13Hxxxxxx 90/110 petrol 2286cc 7:1 CR 141xxxxxx Series II petrol 1997cc 146xxxxxx Series II diesel 2052cc 14Gxxxxxx 90/110 petrol 3528cc V8 151xxxxxx Series II petrol 2286cc 156xxxxxx Series II diesel 2052cc 15Gxxxxxx 90/110 petrol 3528cc V8 (detoxed) 19Jxxxxxx 90/110 turbodiesel 2495cc 236xxxxxx Series IIA petrol 2286cc (fitted to 88 inch airportable) 241xxxxxx Series IIA petrol 2286cc 8:1 CR 251xxxxxx Series IIA petrol 2286cc 7:1 CR 252xxxxxx Series IIA petrol 2286cc 7:1 CR 253xxxxxx Series IIA petrol 2286cc 7:1 CR 271xxxxxx Series IIA diesel 2286cc 276xxxxxx Series IIA diesel 2286cc 286xxxxxx Series IIA petrol 2286cc (Forward Control) 300xxxxxx Series IIA petrol 2625cc (Forward Control) 325xxxxxx Series IIB petrol 2286cc (Forward Control) 330xxxxxx Series IIB petrol 2625cc (Forward Control) 335xxxxxx Series IIB diesel 2286cc (Forward Control) 345xxxxxx Series IIA petrol 2625cc 361xxxxxx Series III petrol 2286cc 8:1 CR 5-bearing 364xxxxxx Series III petrol 2286cc 7:1 CR 5-bearing 366xxxxxx Series III diesel 2286cc 5-bearing 895xxxxxx Series III diesel 2286cc 3-bearing (fitted to 88 inch airportable for export) 901xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 902xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 903xxxxxx Series III petrol 2286cc 8:1 CR 3-bearing 904xxxxxx Series III petrol 2286cc 7:1 CR 3-bearing 906xxxxxx Series III diesel 2286cc 3-bearing 941xxxxxx Series III petrol 2625cc 951xxxxxx Series III petrol 2286cc 3-bearing (fitted to 88 inch airportable) 956xxxxxx 101FC petrol 3528cc V8 961xxxxxx 101FC petrol 3528cc V8 Any idea how to determine what vehicle /yr these engine numbers are from below... apparently 1980's 100's, military.... but I can't tell if these engine numbers can determine year of vehicle or other info ?? 1. E 18J 00030; C233565 2. E 18J00528; C226574 3. E 18J 00375; C231058 4. E 18J 00633; C233741 thanks, mike mrdoiron@gmail.com Quote Link to comment Share on other sites More sharing options...
deep Posted October 17, 2015 Share Posted October 17, 2015 Reviving an old thread but I was surprised to see on my new VIN documentation that my engine number is down as an 18J as well. This is supposedly a 1987 ex-Singapor military and had the huge 24 volt generator (gone now), the nasty Spanish belt-driven vacuum pump and bigger pulleys for a wider belt. Exactly as in those photos, in fact. I have a 19J on the shed floor and the only major differences I can see, other than the obvious turbo, are a completely different breather system and subtly different injection pump. Number 4 in the post above is an engine number remarkably close to mine. They can't have made many as the highest number there is only 00633! Quote Link to comment Share on other sites More sharing options...
