SteveG Posted November 25, 2007 Share Posted November 25, 2007 My Mantec snorkel has been pretty robust so far, but at 7 sisters a tree got the better of it and the top was left being held on by one small piece of plastic and then lots of duck tape So I thought I'd try to repair it, rather than buy another top. The centre section of the mushroom top is connected via 3 plastic spokes to the outside mushroom part. The underside metal grill is then plastic riveted to these 3 spokes. Two spokes had completely sheared off and the third had broken in half at the plastic rivet hole. I bought a pack of four 38mm corner brace brackets from local DIY place for 1.89 and used 4mm bolts and respective nylocs to secure them. Here's the finished item. If you don't mind the look of brakets I would also suggest this a good quick mod to an OK top to give it a bit more strength.. Luckly the brackets lined up well and I could use the existing holes in grill and spokes So I just had to drill the three holes in side of mushroom top. I'll see how long this repair lasts Cheers Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 25, 2007 Share Posted November 25, 2007 Looks a very tidy job Steve. Les. Quote Link to comment Share on other sites More sharing options...
