macandrc Posted November 26, 2007 Share Posted November 26, 2007 Can anyone tell me what size bolts i require for my land rover 90 TD steering cowl? colin Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 26, 2007 Share Posted November 26, 2007 Can anyone tell me what size bolts i require for my land rover 90 TD steering cowl? colin do you mean the shear bolts that hold the ignition switch on? they're M8 or the ones that hold the plastic surround on? they're a mix of long screws and self tappers; screw, pan head, M5 x 40 part # SE105401 (qty x2) (these are the ones that hold the "top" and "bottom" pieces of plastic together screw, M8 x 25 self tapping part # DA608084L (qty x4) (so are these i think ^^^) screw, no 8x 3/8" part # AB608031L (qty2) (these screw into the bottom of the indicator switch unit) screw, pan, M5 x 16 part # SE105161L (qty2) (these ones screw into the ignition barrel lower clasp) Quote Link to comment Share on other sites More sharing options...
