Smokydiesel Posted November 14, 2005 Share Posted November 14, 2005 Hi all, Mister MOT tells me that I need to change the rear suspension bushes on my 88” How difficult is it the get the old ones out and the new ones in ? Do I need any special tools or just brute force ? Thanks in advance for your replies ! Edwin. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 14, 2005 Share Posted November 14, 2005 which bushes? theres ones in the end of the spring, easy enough to push out on fly press or in a vice if necessary, if chassis ones then they normally take a bit more brute force, u can put hacksaw cut from inner hole outwrads which helps or some people burn them out then cut outer tube of bush to get out. Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted November 14, 2005 Author Share Posted November 14, 2005 Hello Tonk, Well both I'm afraid. I'f the chassis bushes need "force"to get them out, will I get them in without a special press ? Cheers, Edwin Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 14, 2005 Share Posted November 14, 2005 they go in alot easier than gettin them out, grease the outside first, i normally use a M12 bolt and a bit of tube to fit them, u can use this method to remove them but r normally too stubborn. poly bushes u can put in by hand, just depends if u want to change to poly's. Quote Link to comment Share on other sites More sharing options...
series3_mad Posted November 14, 2005 Share Posted November 14, 2005 What i did to get the bushes out was sprayed them wd40 and left it for a day the cut the middle tude with a hacksaw, pulled the rubber bit out with a pair grips and then cut the outer tude with a hacksaw then used a hammer and chisle to get them out. Quote Link to comment Share on other sites More sharing options...
andyb Posted November 15, 2005 Share Posted November 15, 2005 they go in alot easier than gettin them out, grease the outside first, i normally use a M12 bolt and a bit of tube to fit them I've found that putting them in the freezer over night helps too. Take them out just before you are going to put them in. Quote Link to comment Share on other sites More sharing options...
SeriousIIa Posted November 22, 2005 Share Posted November 22, 2005 Hi Edwin, There are some pics of bush changing on my website: Bush changing Hope they are of some help. Cheers BOwy Quote Link to comment Share on other sites More sharing options...
