smo Posted December 14, 2007 Share Posted December 14, 2007 What brackets etc will i need to fit a 2nd alternator on my TD5, i shall be using the "spare" space where the air con pump would go. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 14, 2007 Share Posted December 14, 2007 What brackets etc will i need to fit a 2nd alternator on my TD5, i shall be using the "spare" space where the air con pump would go. Someone on devon 4x4 did it, i plan to on my 110 when it's bult as well. think you'll have to fabricate your own bracket, but a piece of 5mm plate and 4 welded on lugs to mount the alternator onto should do the trick. If you get the pulley at similar height to the AC compressor, you'll be able to use a standard AC fanbelt too. Quote Link to comment Share on other sites More sharing options...
smo Posted December 14, 2007 Author Share Posted December 14, 2007 I definatly intend on using the AC belt, finding an alternative length belt that fits would be a mare! I shall find a 24V alternator first and get fabbing! Quote Link to comment Share on other sites More sharing options...
