cress Posted December 21, 2007 Share Posted December 21, 2007 Hello again, 2 in a row, On my 300Tdi, occasionally when travelling at speed the speedo drops to zero. I have tried changing speed and this made no difference. Then just as it drpped to zero it can zoom back to indicate speed. This does not happen often, It has lasted from between 30 seconds to 30 minutes. Is this likely to be the speed sensor if so where is it? or is it more likely to be a bad connection somewhere? Any help much appreciated. Ivan Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 21, 2007 Share Posted December 21, 2007 Speed sensor is the most likely cause - it's on the transfer box Quote Link to comment Share on other sites More sharing options...
Mark Posted June 6, 2008 Share Posted June 6, 2008 Dragging this to the top again, as my speedo was playing up this morning on the drive to work, followed by it not working at all... is it a question of rplaceing the senso, or just cleaning up the connections? anyone got a part number for the sensor? ta Mark Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 6, 2008 Share Posted June 6, 2008 All the ones I have seen with problems have worked once a new sensor was fitted but I suppose you could try cleaning the connections first. The sensor isn't very expensive IIRC. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 6, 2008 Share Posted June 6, 2008 Does this sound right? YBE100540 SPEED TRANSDUCER 90/110 V8 DISCO 1 95 ON £37.30 Seems a little pricey-er than I was expecting... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 6, 2008 Share Posted June 6, 2008 Oh. I thought it was about £15 or so. Guess not Have you tried Bearmach etc for a non gen one? Quote Link to comment Share on other sites More sharing options...
Mark Posted June 6, 2008 Share Posted June 6, 2008 No I havn't, but I am starting to shy away from non gen/OEM stuff... Local dealer has one in stock, so I will grab that and see if it fixes it... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 6, 2008 Share Posted June 6, 2008 How about a scrapyard? Quote Link to comment Share on other sites More sharing options...
