ibexman Posted November 16, 2005 Share Posted November 16, 2005 Can you flick in an arb locker whilst on the move??? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 16, 2005 Share Posted November 16, 2005 yes, and off again, I only turn them on for that particularly nasty bit and straight off again Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 16, 2005 Share Posted November 16, 2005 Yep, what he said ^^^^^^^^^^^^^^^^. Although I wouldn't try it on the road at speed!! and don't expect it to unlock instantly if still under load - you'll need to back off the loud pedal for a sec to enable it to unlock. (Particularly important with a front locker if you're trying to go round a corner!! ) Quote Link to comment Share on other sites More sharing options...
D9OSV Posted November 16, 2005 Share Posted November 16, 2005 Both are right, However...... To engage fully the diff should be off load and lke wise, before it will disengage load must be removed. just bear that in mind when using them. Don't nail the button when spinning a wheel for example Jim Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 17, 2005 Share Posted November 17, 2005 Don't nail the button when spinning a wheel for example Jim Otherwise you can break the locking ring........ I often engage the lockers when I'm moving slowly, just to make sure they're in properly. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 17, 2005 Share Posted November 17, 2005 when I'm moving slowly never actually seen u move quickly Quote Link to comment Share on other sites More sharing options...
