simon red90 Posted January 1, 2008 Share Posted January 1, 2008 ok, so i was out at kirton on suday just. i go to spool out the front winch and it does nothing, just spins the motor. 2nd attempt and all the brake is spat off the side. shearing the end bolt. looking at it, the splined cam (which is warn part no 7562) has smashed to pieces. taking the mainshaft bush and seal with it. my winch is running a 12v bowmotor, has the uprated mainshaft on it already, and a narrow diameter drum. also it is only just a year old. i've got no problems replacing broken parts but i'd rather know a reason for part failure before i do to prevent future failures! has anyone else had such a problem or was my wich put together with plasticene not metal?! cheers. si Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted January 1, 2008 Share Posted January 1, 2008 If you bought the shaft from Jim Gigglepin speak to him and a cam gear will appear as if by magic and your problems will be history! Quote Link to comment Share on other sites More sharing options...
simon red90 Posted January 1, 2008 Author Share Posted January 1, 2008 If you bought the shaft from Jim Gigglepin speak to him and a cam gear will appear as if by magic and your problems will be history! a phone call will be made! cheers. si Quote Link to comment Share on other sites More sharing options...
simon red90 Posted January 3, 2008 Author Share Posted January 3, 2008 If you bought the shaft from Jim Gigglepin speak to him and a cam gear will appear as if by magic and your problems will be history! spoke with jim yesterday, what a top bloke. problem sorted. cheers to jim and all at gigglepin. si Quote Link to comment Share on other sites More sharing options...
