Hendrik Posted January 3, 2008 Share Posted January 3, 2008 Hi, Can someone tell me how much flow the standard defender brakepump provides? thx Hendrik Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2008 Share Posted January 3, 2008 if you mean the vacuum pump it doesn't blow but sucks = vacuum, the workshop manual doesn't give any figures or information on the vacuum pump. Quote Link to comment Share on other sites More sharing options...
Hendrik Posted January 3, 2008 Author Share Posted January 3, 2008 It's about the master cylinder (wasn't sure about the name) part number NRC9529 for a 90 and NRC8690 for a 110/130. Thx H. Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2008 Share Posted January 3, 2008 Ok, that won't have a flow rate as it doesn't pump like a power steering pump does, it just transmits pressure, again no further info in the workshop manual. Quote Link to comment Share on other sites More sharing options...
TomG Posted January 3, 2008 Share Posted January 3, 2008 Do you mean the volume of fluid (e.g. in cc) the master cylinder pumps in a single full stroke of the pedal? Not that i know the answer, but i guess you could measure it by disconnecting a pipe from the master cylinder and diverting it into a container. Max flow rate is probably achieved in one of those moments when you're bowling along at 70mph and a deer or something jumps out in front of you Quote Link to comment Share on other sites More sharing options...
Hendrik Posted January 3, 2008 Author Share Posted January 3, 2008 Indeed tom, That's what I'm looking for... I installed wilwood brakes but after getting all the air out of the circuit, it's still not braking well (like a sponge...). Now we think that the "volume" that the cilinder pumps is not big enough for the wilwoods... Quote Link to comment Share on other sites More sharing options...
TomG Posted January 3, 2008 Share Posted January 3, 2008 Hendrik, There's a thread about this on the difflock forum in the extreme offroading section, look under 'Volvo axles disc brakes conversion' mentions using a Volvo master cylinder. Mods: Is it acceptable to post the link to another forum or not? Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2008 Share Posted January 3, 2008 Yes, quite acceptable to post a link to other related LR info. Quote Link to comment Share on other sites More sharing options...
TomG Posted January 3, 2008 Share Posted January 3, 2008 http://forum.difflock.com/viewtopic.php?t=15262 Sorted B) Quote Link to comment Share on other sites More sharing options...
MogLite Posted January 3, 2008 Share Posted January 3, 2008 Willwood also make master cylinders. I've got one of theirs on my Range Rover servo in MogLite. MogLite needed a big master cylinder for the Unimog slave cylinders. I think mine is 1 1/8" so it moves a lot more fluid. Willwood should be able to recommend a master cylinder size for your brakes. Andy Quote Link to comment Share on other sites More sharing options...
Hendrik Posted January 3, 2008 Author Share Posted January 3, 2008 Thanks guys, Seems to be the same problem as I have... will look tomorrow at my type of calipers and try to contact Rally design for a Brake MC! keep you posted! H. Quote Link to comment Share on other sites More sharing options...
