Interior lights in CSW
Wiring diagram shows both lights connected to earth on header joint K109.
power feed on purple wire to passenger compartment fusebox Fuse 2.
& connected to the Alarm ECU D111 on a purple/white wire
door switches also go to the D111 [Alarm ecu] on a Purple/Blue wire Left door & Slate/White wire Right door, rear end door also on Purple/Blue to D111.
rear side door switches as for rear end door switch.
hope that helps :D
hope that helps :D
It helps but makes it more complicated than I was hoping.
Where is the alarm ecu located?
infact how is the alarm activated?
