goaty Posted January 13, 2008 Share Posted January 13, 2008 Hi, I think my a frame ball joint needs changing but am unsure. When on motorways/dual carriageways when accelerating then backing off to change gear or just backing off the power, the car has a little unsteadyness to it. Near enough all bushes have been replaced recently apart from the a frame, that untouched. Can anyone tell me if i am guessing right or not??? thanks joe Quote Link to comment Share on other sites More sharing options...
western Posted January 13, 2008 Share Posted January 13, 2008 if you've elimnated all other possible causes, your most likely right. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 13, 2008 Share Posted January 13, 2008 Attack it with a tyre lever to find out. Quote Link to comment Share on other sites More sharing options...
101sean Posted January 13, 2008 Share Posted January 13, 2008 When they get bad they usually clonk as you go on and off the throttle. Quote Link to comment Share on other sites More sharing options...
robhybrid Posted January 13, 2008 Share Posted January 13, 2008 Just double check all your track rod ends and the tightness of the bolts to the front pan had rod. I have had similar symptoms when the pan had rod was slightly loose, a mate of mine had similar symptoms when his drop arm track rod end had worn slightly. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted January 14, 2008 Share Posted January 14, 2008 Goaty If you do change it you will need a press to push the old one out and the new in I tried it - without a press had to heat to red hot and broke a my vice trying to push the new one in Bugger of a job Steve Quote Link to comment Share on other sites More sharing options...
goaty Posted January 14, 2008 Author Share Posted January 14, 2008 will double check everything before i take it apart as i noticed it yesterday on my way home from a pay and play at Boxgrove. Fair chance i knocked a few things loose. cheers Quote Link to comment Share on other sites More sharing options...
