yellowmitch Posted January 15, 2008 Share Posted January 15, 2008 Hi there. I have an 89 rangie which originally had a 3.5v8 in it. It now has a 200Tdi in it, which is great! Thing is, when I got it, pretty much everything worked with the exception of the heater plugs. I would like these to work and have bought a genuine Lucas red glow plug timer relay. My question is, how do I wire this up? I need to wire the plugs up themselves firstly (they are fitted and linked together with loops of wire) Then I need to wire the relay up to the plugs and finally, I need the relay connected to the ignition live and the output of it (which I presume goes to the plugs) to also illuminate the choke lamp in the binnacle Hence, hey presto, I will have a retro fitted glowplug heating system So how do I do it and what are the pins on the relay timer? Yay!! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 21, 2008 Share Posted January 21, 2008 The 4 plugs are looped togher in parallel (the cases are all "earthed" through the engine block, and the screw terminal on top has the +ve) the one nearest the bulkhead has the extra wire that joins onto the relay. to connect the relay Have a look at Nicks Jungle scroll down a little way and you'll see all the wiring for the relay. the relay itself is a ford part! even from the factory they're fitted with ford relays! Quote Link to comment Share on other sites More sharing options...
yellowmitch Posted January 21, 2008 Author Share Posted January 21, 2008 The 4 plugs are looped togher in parallel (the cases are all "earthed" through the engine block, and the screw terminal on top has the +ve)the one nearest the bulkhead has the extra wire that joins onto the relay. to connect the relay Have a look at Nicks Jungle scroll down a little way and you'll see all the wiring for the relay. the relay itself is a ford part! even from the factory they're fitted with ford relays! This is all mega handy stuff to know. Another thing that I THINK i might have discovered is this..... Is the relay already fitted to the Rangie up in under the dash and just not wired up? I have a feeling it is, as I have found one in there that looks the same. How do I know what all the big relays (mostly lucas) up under the dash to the right of the steering column are? Looking forward to hearing. Thanks Mitch Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2008 Share Posted January 21, 2008 http://forums.lr4x4.com/index.php?showtopic=1274 this might help you connect it, in conjunction with the info in the link DJ has given you. Quote Link to comment Share on other sites More sharing options...
