jas97disco Posted January 15, 2008 Share Posted January 15, 2008 Hi all , can anyone advise on when I should next change the timing belt on a 97 300TDi auto. Changed it at 66k Miles (no yellow square so assuming they didn't fit the revised pulley kit) and its now at 118K, so current belts done 52K miles). Many Thanks - Jason Quote Link to comment Share on other sites More sharing options...
Oliver Posted January 15, 2008 Share Posted January 15, 2008 Howdy, I would say it would be time to do it again and check that the lower pulley has the 'lip' on it to prevent the belt running off etc. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 15, 2008 Share Posted January 15, 2008 Depends on how you are using it - towing, off-road, etc means it should be changed at 36k miles. Better sooner than later anyway. Les. Quote Link to comment Share on other sites More sharing options...
Thys Posted January 17, 2008 Share Posted January 17, 2008 Hi all , can anyone advise on when I should next change the timing belt on a 97 300TDi auto.Changed it at 66k Miles (no yellow square so assuming they didn't fit the revised pulley kit) and its now at 118K, so current belts done 52K miles). Many Thanks - Jason Remember my sock episode................................ Quote Link to comment Share on other sites More sharing options...
