whoisashley Posted January 18, 2008 Share Posted January 18, 2008 Hi my V8 Classic refuses to run smoothly until warmed up . Before, this was not too bad but now if i walk away for to long she stalls. Is it possible to adjust the automatic choke as i thing it isn't opening up enough when first started, or is it something else? Quote Link to comment Share on other sites More sharing options...
paintman Posted January 18, 2008 Share Posted January 18, 2008 Carbs or EFi? Quote Link to comment Share on other sites More sharing options...
whoisashley Posted January 19, 2008 Author Share Posted January 19, 2008 Carbs or EFi? Its an EFI Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 19, 2008 Share Posted January 19, 2008 I'll guess flapper then ? Prob the Extra Air Valve, its the thing on the front of the inlet manifold next to the thermostat thingy Have a habit of dying, they can be obtained sh cheap cheap cgheap, I haven't got one sorry, think they are hideously silly spendy new so ask on classifieds here ? I assume that once warmed up all OK, if not then suspect CTS HTH Nige Quote Link to comment Share on other sites More sharing options...
whoisashley Posted January 20, 2008 Author Share Posted January 20, 2008 I'll guess flapper then ?Prob the Extra Air Valve, its the thing on the front of the inlet manifold next to the thermostat thingy Have a habit of dying, they can be obtained sh cheap cheap cgheap, I haven't got one sorry, think they are hideously silly spendy new so ask on classifieds here ? I assume that once warmed up all OK, if not then suspect CTS HTH Nige Brilliant thanks for that Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 20, 2008 Share Posted January 20, 2008 Just wait till you try to get the plug off / remove the 2x bolts holding it Thats should remove any happiness Bit of a PITFA type jobbie Nige Quote Link to comment Share on other sites More sharing options...
paulwrigley Posted January 22, 2008 Share Posted January 22, 2008 Just wait till you try to get the plug off / remove the 2x bolts holding it Thats should remove any happiness Bit of a PITFA type jobbie Nige My mate and I have a Rangie (1987 3.5EFI auto) that does exactly the same. Tried a new (second hand extra air valve - your right, it is a pain in the a£$e) and it didn't make any difference. . Been asking all over the place (only just found this place ) and the latest is "try the M.A.F". Any thoughts? ps. sorry to hijack the thread Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 22, 2008 Share Posted January 22, 2008 My mate and I have a Rangie (1987 3.5EFI auto) that does exactly the same. Tried a new (second hand extra air valve - your right, it is a pain in the a£$e) and it didn't make any difference. .Been asking all over the place (only just found this place ) and the latest is "try the M.A.F". Any thoughts? ps. sorry to hijack the thread MAF ????? Do you mean Manifold air Temp Sensor - Erm - isn't one :LOL; Or Air Flow Meter ?...in which case yes possibly.... but when these go wrong often the whole rev range misbehaves and coughs and gurgles CTS - coolant temp sensors can also cause misfires poor running / rich running However for start up the EAV often being just a basic bimetal strip get glued up with carbon deposits and muck, a new one often sorts it out Nige Quote Link to comment Share on other sites More sharing options...
