BiggerBaloo Posted January 18, 2008 Share Posted January 18, 2008 As the title says, everytime I go through a big puddle (not a lake, but anything more than 2 inch deep) it feels like I lose power steering for a few seconds (5 max). As I'm completely clueless can anyone give me a hint of what to stand and look at for a couple of hours before taking it in to a garage? Thanks in advance Martin Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 18, 2008 Share Posted January 18, 2008 Water on the power steering belt makes the belt slip. May be worse if the belt is a bit slack but if it's a 300Tdi as your signature suggests, there is nothing that you can do about it as the tensioner is automatic. Quote Link to comment Share on other sites More sharing options...
88 Nick Posted January 18, 2008 Share Posted January 18, 2008 I had that problem,was just the power steering pump belt slipping,check its tight or replace it. Cheers Nick Quote Link to comment Share on other sites More sharing options...
BiggerBaloo Posted January 18, 2008 Author Share Posted January 18, 2008 Cheers guys. Yeah it is a Disco 300tdi. If it was the belt slipping would I be able to hear it (like an alternator belt)? For the price of a new belt I'll put one on when I get a bit of spare time in daylight Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 18, 2008 Share Posted January 18, 2008 Cheers guys. Yeah it is a Disco 300tdi. If it was the belt slipping would I be able to hear it (like an alternator belt)? For the price of a new belt I'll put one on when I get a bit of spare time in daylight You wouldn't necessarily hear it if it's wet, no, although it may squeak a bit when it dries and grips again. Quote Link to comment Share on other sites More sharing options...
pinny Posted January 18, 2008 Share Posted January 18, 2008 You wouldn't necessarily hear it if it's wet, no, although it may squeak a bit when it dries and grips again. same prob here every month i have been getting a coarse piece of sandpaper whilst engine is running ive held the paper on the belt at the waterpump for approx 30 seconds this roughens the belt up and its fine for a while as the power steering runs on the smooth side of the belt i also cleaned all the pulleys with brake and clutch cleaner chris. Quote Link to comment Share on other sites More sharing options...
BiggerBaloo Posted January 18, 2008 Author Share Posted January 18, 2008 Is there a way to adjust the automatic tensioner??? just thinking out loud. Quote Link to comment Share on other sites More sharing options...
freeagent Posted January 18, 2008 Share Posted January 18, 2008 Not that I know of, although its possible the spring might have gone and you'll need a reconditioned unit. I'd try buying a new, genuine parts belt (available from Paddocks for about £10, made by Gates or Dayco) and stick that on... Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 18, 2008 Share Posted January 18, 2008 Slow down , You may be aquaplaning Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2008 Share Posted January 18, 2008 My 200Tdi does it too, big puddle drive through it steering gets really heavy for a minute or two, then is OK again. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 19, 2008 Share Posted January 19, 2008 The tensioner sometime gets gunked up with mud. Pop it off and soak in diesel overnight/liberally coat with WD40/move it around a bit... Quote Link to comment Share on other sites More sharing options...
BiggerBaloo Posted January 19, 2008 Author Share Posted January 19, 2008 The tensioner sometime gets gunked up with mud. Pop it off and soak in diesel overnight/liberally coat with WD40/move it around a bit... Aye, never thought of that, I'll have a look, cheers Quote Link to comment Share on other sites More sharing options...
