Serhiy Posted January 21, 2008 Share Posted January 21, 2008 Does anyone know where fuel cut off switch on Discovery 91YM 3.5 EFI hot wire is located? After small incident fuel is not coming to engine bay. I can not find English version of the factory workshop manual for this model on the web, maybe someone knows where it could be downloaded from? Quote Link to comment Share on other sites More sharing options...
Serhiy Posted January 25, 2008 Author Share Posted January 25, 2008 Unfortunately nobody knows where this switch it is...... There is no Rave description of this model.....There is no factory Workshop manual for this model on the web..... There is no electrical diagram on the web.....Complete disaster..... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 25, 2008 Share Posted January 25, 2008 I thought somebody posted a link to a Disco 200Tdi age (which would cover yours) workshop manual for download just in the last week or so, but I don't have time to look for it at the moment, I'm sure its on here somewhere though! These switches are normally located in the engine bay. If all else fails you could try and follow the wiring back from the pump I suppose. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 25, 2008 Share Posted January 25, 2008 If it's flapper EFi it may not have one, I've never seen one on a flapper setup anyway. Quote Link to comment Share on other sites More sharing options...
Ivan Posted January 25, 2008 Share Posted January 25, 2008 It's not a flapper it's a Lucus 14CUX. I think it's located somewhere behind the dash board. It's a long time since mine had a 200 body fitted so I can't remember sorry. On a 300 series it's behind the washer bottle. Ivan Quote Link to comment Share on other sites More sharing options...
Serhiy Posted January 25, 2008 Author Share Posted January 25, 2008 It's not a flapper it's a Lucus 14CUX. I think it's located somewhere behind the dash board. It's a long time since mine had a 200 body fitted so I can't remember sorry. On a 300 series it's behind the washer bottle.Ivan It is not flapper. It is definitely hot wire Lucas 14 CUX, exactly like on 3.9 engine. ECU is located near the right edge of the dash board. There is nothing behind washer bottle like in later models (it was first place I have checked before posting topic on the board). Link between pump fuse and pump connector is broken, so this is 100% inertia switch. I still belive in wisdom of LR engineers and can not even imagine that they expected someone driving Camel Trophy rig in the bush to remove dash board to push button on this switch after small accident. It looks that Workshop manual for this model is best kept secret of Land Rover . Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 25, 2008 Share Posted January 25, 2008 Camel Trophy ones are 200Tdi's, but you have a valid point! Have a look under the front seats, I seem to remember some of the older Range Rovers had one there? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 25, 2008 Share Posted January 25, 2008 A quick search revealed that older 80's RR inertia switches are supposed to be under the passenger seat, check there. A common fault being to bang it with the hoover when cleaning inside! Quote Link to comment Share on other sites More sharing options...
Serhiy Posted January 25, 2008 Author Share Posted January 25, 2008 I checked everything underneath both seats even before posting this topic, as I have some V8 RRC experience, but, in contrast to Range Rover, neither ECU, nor relays, nor inertia switches were not found in Discovery. 14 CUX ECU is screwed to the body panel close to right edge of the dash board, practically under dash board. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 26, 2008 Share Posted January 26, 2008 Sorry, I don't have any other ideas at the moment then. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 28, 2008 Share Posted January 28, 2008 Well, it definitely has an inertia switch according to microcat .............. Part Number DBC2022L from VIN LA changing again from VIN MA It also shows a shield / cover around the switch and it is the only other component shown on the ECU page, so I'm guess it must be somewhere close to the ECU.. Ian Quote Link to comment Share on other sites More sharing options...
SteveRK Posted January 29, 2008 Share Posted January 29, 2008 Maybe behind one of the footwell kick panels? That said normally these switches are accessible without having to remove panel trim. On the RR it is under the passenger seat with the ECU under the dirver's seat. If the ECU for the Disco' is up under the dash then the cut-out shouldnt be too far away Quote Link to comment Share on other sites More sharing options...
