disc change over
As long as you get the correct pads for your calipers the same pads fit both vented & non-vented discs (when used with a caliper spacer kit) as the shape & size of the back-plate & friction area does not alter, only the gap between the two caliper halves.
I used a spacer kit (not the Zeus one) and it works very well. The cost was about £50, all the parts were in the kit and as the calipers had been rebuilt only a year or so beforehand they came apart very easily. I think I had the whole job done in about 3-hours (replace discs, fit spacer kit, bleed brakes etc).
