p38 not set fault reading and eas fault
shaune
Hi all
my p38 has suddenly started playing up. when i turn the ignition on various fault displays come up, such as left hand window not set, ring hand not set etc, also says eas fault and all four of the height display lights are permantly on. also every time i put a window up or down fault reading come s up.
does any one have any idea what this may be
thanks
shaun
Have you recently disconnected the battery?
Once reconnected you have to reset all the windows and sunroof by cycling them
through their full range of movement and holding the button down afew seconds
at each stop point.
As for the EAS, you need diagnostic equipment to read the fault and then clear it.
untill then it will just stay as is, and your car may end up on the bumpstops.
