western Posted November 28, 2005 Author Share Posted November 28, 2005 (edited) Looks to me like it's been blowing bottom of #2 cylinder and rear of #4? Head gasket wasn't showing any signs of leakage and there's no burn marks on the head/block faces, hopefully it'll be going back together starting tomorrow evening Wed evening, Got all the bits I need for the rebuild, started yesterday [Tuesday] evening, replacemant cam [ Thanks Les.] and followers are in, had to check the sliders were in the correct way as there marked 'Front' all checked out fine, block & head face cleaned up ready for refit, just changing the valve stem seals, as I have new ones so may as well use them, so far valves are fine, hopefully get that finished tomorrow & bolt the head/manifolds back in place, Edited November 30, 2005 by western Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2005 Author Share Posted December 2, 2005 (edited) Finished changing the valve stem seals last night, all the valves are fine-no bent ones this afternoon I've cleaned the timing case ready for refit, cylinder head is now refitted with a new gasket & bolts torqued to the required setting, manifolds, turbo oil pipes, pushrods & rocker shaft all fitted Tomorrow's job is to refit the timing case rear part, refit alternator, power steering pump, pulleys & timing belt [new] set the timng, valve gaps, and all the other bits ready for start-up Edited December 2, 2005 by western Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2005 Author Share Posted December 4, 2005 I'm a happy bunny my 110 is back on the road, running beautifully Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 4, 2005 Share Posted December 4, 2005 I'm a happy bunny my 110 is back on the road, running beautifully Well done Ralph. I know that feeling Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2005 Author Share Posted December 4, 2005 Cheers Trev did a road test earlier all OK, my turn to drive to work tomorrow. Quote Link to comment Share on other sites More sharing options...
landi41 Posted December 4, 2005 Share Posted December 4, 2005 Cheers Trev did a road test earlier all OK, my turn to drive to work tomorrow. Good for you Ralph.......... must you remember to re-torque the head at some time? Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2005 Author Share Posted December 4, 2005 No need on this engine Dave, least there's no mention of a retorque in the offical manual Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 4, 2005 Share Posted December 4, 2005 That's good Ralph, well done. First time I've ever re-profiled a camshaft with an angle grinder. Glad it worked! Les. Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2005 Author Share Posted December 4, 2005 That's good Ralph, well done. First time I've ever re-profiled a camshaft with an angle grinder. Glad it worked! Les. you did a bl**dy good job then, valve caps set-up really easy, runs as well as before, I'll take the intercooler to work and give it a good clean before bringing it up Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2005 Author Share Posted December 5, 2005 Took my 110 to work today, first long run since it went duff, I'm well pleased it drove really well,plenty of grunt and as responsive as a 200Tdi can be just one little problem the oil temp gauge wanted to stay at the 'Hot' end of the scale a few words with the sender connector from Mr Pliers stopped that silly game next weekend I'll do a oil/filter change,remove the sump for a good clean & clean the strainer of the oil pump Quote Link to comment Share on other sites More sharing options...
