Shaggy Posted January 26, 2008 Share Posted January 26, 2008 This is what my £200 got me. I rekon its nice. Just one question. I seem to have two straps hanging down from the roof on the last pic. Any idea where they go? Quote Link to comment Share on other sites More sharing options...
wkw90 Posted January 26, 2008 Share Posted January 26, 2008 Nice job for £200 Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 26, 2008 Share Posted January 26, 2008 Those two straps should loop around the back of the rollbar and then go forward towards the windscreen again. you should also have 2 shorter straps, about 12" long, a hook on one end and one of those little aluminium "lock off" buckles on the other. you hook the hook end onto the metal bar that holds the front of the canvas down, and thread the loose straps through each of the buckles, so you can "tighten" the piece of roof above your head (like where a sunroof would be) to stop it flapping when you're driving. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 26, 2008 Share Posted January 26, 2008 ^^^^^^^^^^^^^E's right^^^^^^^^^^^^^^^^^^^^ Although you tension those straps before you tension it at the back. If you don't - it gives your canvas that rather tatty 'straight out of the tumble dryer' look Les. Quote Link to comment Share on other sites More sharing options...
smo Posted January 26, 2008 Share Posted January 26, 2008 £200 bargain if the finish is half as good as it looks. Did that include prep and was it stripped properly first or just masked and sprayed round everything? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 26, 2008 Share Posted January 26, 2008 ^^^^^^^^^^^^^E's right^^^^^^^^^^^^^^^^^^^^Although you tension those straps before you tension it at the back. If you don't - it gives your canvas that rather tatty 'straight out of the tumble dryer' look Les. You mean you never ironed your canvas Les? Where's yer attention to detail man! Quote Link to comment Share on other sites More sharing options...
Big_John Posted January 26, 2008 Share Posted January 26, 2008 Looks good to me. Is it still yellow on the inside? Can see a bit of yellow here and there so i assume so. initially I had great plans to respray mine something a bit more subtle, but the effort of sorting out the inside has put me off. Quote Link to comment Share on other sites More sharing options...
Shaggy Posted January 26, 2008 Author Share Posted January 26, 2008 He stripped it down, I know this cos I went to check up on him He spent Monday to Thurs preparing it, then gave it four coats Friday/Sat. He even done the inside of the bonnet to my ammazement. He said he would not touch it and we had discussed me hammerite'ing it. So I was well chuffed when I got home, lfted the bonnet to begin the hammerite painting, and it was done. I touched up the rubber along the back door this evening that you can see is yellow, i done it with a cheap artisit brush. I will roller the bits he could not do along the rear door edges that are hidden by the Tarp Roof, inside, I think all I will do it rub down and Hammerite it black. I will then Hammerite Matt Black the plating. So the Dangly Bit i just need to pull round the front Rool bar and tie up somewhere? Sorry I am a plumb Quote Link to comment Share on other sites More sharing options...
siearl Posted January 26, 2008 Share Posted January 26, 2008 That is one hell of a paint job for 200 sheets, looks really good Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2008 Share Posted January 26, 2008 So the Dangly Bit i just need to pull round the front Rool bar and tie up somewhere? pass it over the bar & around the back of the bat then pull them towards the front screen, then connect to the short bits as DJ described above. Quote Link to comment Share on other sites More sharing options...
Shaggy Posted January 28, 2008 Author Share Posted January 28, 2008 Chequer Plate Done. Needs another coat. Do that at the weekend unless i can swing an early one Need to do the inside as well and in those vents where you can see the yellow. Quote Link to comment Share on other sites More sharing options...
jonost24 Posted January 28, 2008 Share Posted January 28, 2008 Looking really good. Excuse my ignorance on ragtops, but is that clingfilm inside the canvas?? Cheers, Jon Quote Link to comment Share on other sites More sharing options...
Shaggy Posted January 28, 2008 Author Share Posted January 28, 2008 No idea Jon. Was on the vehicle when I bought it. Quote Link to comment Share on other sites More sharing options...
alantd Posted January 29, 2008 Share Posted January 29, 2008 Looks like a fantastic job for £200. First class - love the matt look. Quote Link to comment Share on other sites More sharing options...
Shaggy Posted January 29, 2008 Author Share Posted January 29, 2008 Cheers Alan Quote Link to comment Share on other sites More sharing options...
billypikey Posted February 5, 2008 Share Posted February 5, 2008 £200 for that paint job Quote Link to comment Share on other sites More sharing options...
letsgodisco Posted February 5, 2008 Share Posted February 5, 2008 This is what my £200 got me. I rekon its nice. Just one question. I seem to have two straps hanging down from the roof on the last pic. Any idea where they go? Nice! worth every penny!! Quote Link to comment Share on other sites More sharing options...
Shaggy Posted February 5, 2008 Author Share Posted February 5, 2008 Thanks. Im well pleased with it Quote Link to comment Share on other sites More sharing options...
Guppy Posted February 5, 2008 Share Posted February 5, 2008 Looks brand spanking new! Wish I could afford a new paintjob! Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 6, 2008 Share Posted February 6, 2008 Can I ask what colour that is? I think it looks great and wouldn't mine re-doing mine in that Quote Link to comment Share on other sites More sharing options...
Shaggy Posted February 6, 2008 Author Share Posted February 6, 2008 NATO Green in Matt. Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 6, 2008 Share Posted February 6, 2008 Is that what they refer to as Nato green sand? Where did you get it from? Thanks Quote Link to comment Share on other sites More sharing options...
Jammy123 Posted February 6, 2008 Share Posted February 6, 2008 Is that what they refer to as Nato green sand?Where did you get it from? Thanks Nato Green Sand - That makes no sense! There is NATO green (olive drab colour), and NATO sand (a desert, sandy colour). I've just had a look and you can buy it from http://www.anchorsupplies.com/paint.htm Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 6, 2008 Share Posted February 6, 2008 Nato Green Sand - That makes no sense! There is NATO green (olive drab colour), and NATO sand (a desert, sandy colour). I've just had a look and you can buy it from http://www.anchorsupplies.com/paint.htm Sorry, missed the '/' on some of the threads I was reading. I found Anchors and they do green, black and light stone but it's the drab green I like Quote Link to comment Share on other sites More sharing options...
Shaggy Posted February 6, 2008 Author Share Posted February 6, 2008 Cant remeber where i got mine. Leevsey or something like that Quote Link to comment Share on other sites More sharing options...
