Rust in footwells
depends how bad it is...
is there enough good metal to bolt the chequer plate to?
i dont know where im going with this....
pretty much, just cover it in oil and stick some bits of metal to it :D
did mine recently, removed the floor plates & tunnel, cut out the bad stuff under the pedals & similar place on left side, then made up some repair plates with 2mm steel sheet, must get the floor plates & their seals sorted out & fitted correctly, loads of under seal & paint covering the new steel, should be good for another 14 years.
It's not unusual for 90/110's to rot away there. The pad of foam that sits between the bulkhead outrigger helps things along, and the double skin is a dirt trap too.
The lower part of the footwell can be repaired without any major work though - just cut it out and weld a new plate in (single skin, but thicker metal to compensate for that)
Les.
Thought i'd chuck in my 2 bits:
Been going out to the truck in the mornings for the last few (wet) weeks and finding a puddle in the passenger footwell. Thought it was the door seals - and it was...to an extent!
After sorting those, and replacing perished sealant elsewhere, I still had a puddle.
Turns out that the bonnet gutter seal was 3 inches shorter than it needed to be, and rain water was dripping off the gutter into the engine bay on both sides - but on the passenger side it pooled up around the heater mounting brackets and after a while had simply rotted a way into the footwell.
Might be a help to someone!
Get a wire brush in a grinder on it, that will find what good metal's left...
Before - just an ickle hole, surely?
After - full extent revealed:
Cut out the rubbish and weld in a good bit, or if you really can't stretch to welding, riveting in a panel (with a liberal application of seam sealer) would also work although it may look a bit naff. It's a flat bit so not too complex to make a new bit, although genuine footwell repair panels are cheap enough from Paddocks et al.
