Anit-corrosion fuel tank options?
Guest wunntenn
Guest wunntenn
Time for renewing my 110's fuel tank, and wanting to install something that's not prone to rust so's I can forget it for a good few years. Whats the best at resisting corrosion? Checked the archives and didnt find anything.
Stainless? (expensive)
Alloy? (also expensive).
What about galvanized ones? (are they available and cheaper?)
Sources?
Or...is it just as useful to get a normal tank and give it several coats of galvafroid and top it off with waxoyl black underseal?
If you get a quote for an Allisport tank, make sure you're sitting down with a stiff drink to hand. Beautiful work, but HOW much? :blink: :blink: :blink:
Cover it in paint and don't leave it under a land rover for 20 years without checking every so often for damage to the coating.
Guest wunntenn
I'd seen that thread Western, but wondered if there was any other info as there was some uncertainty over what it was you'd got exactly! Thanks anyway, I'll sit down with a stiff one (drink that is!).
I got me an extra tank for my 90 made up by Safari-Equip out of Aluminum
http://safari-equip.co.uk/index.php?page=4
Had it double skinner so I don't have to add a guard (in theory), I guess this will not rust and 'should' last for a long time...
I am sure you could get one for the 110, I bet you could even get one made bespoke to give you more fuel storage if you wanted, might cost a bit more than a plastic tank though?
