BAZZA999 Posted January 28, 2008 Share Posted January 28, 2008 HI THERE THIS IS MY FIRST LISTING SO I HOPE ITS OK. I HAVE A 1999 T PLATE LANDROVER DISCOVEY SERIES 2, 4.0 V8I ES MODEL. IT HAS A GAS CONVERSION BY ZAVOLI WHICH IS A SEQUENTIAL MULIT POINT SYSTEM. I HAVE JUST HAD IT INTO MY LOCAL LANDROVER INDEPENDENT SPECIALIST WHERE IT HAS HAD TO HAVE TOP ENGINE OVERHAULL CASTING £2,099. NEW VALVES, NEW CAM SHAFT,NEW GASGETS, PLUGS, HT LEADS, THROTTLE BODIES ETC ETC ETC. HERES THE PROBLEM FOLKS ! ! ! ! ! ! . WHEN IT RUNS ON GAS IT IS ABSOLUTLY SPOT ON, LOADS OF POWER ETC. WHEN I START UP THE CAR IN THE MORNING FROM COLD AND LEAVE IT TO TICK OVER ON PETROL ITS OK, AS SOON AS I PUT THE ENGINE INTO GEAR AND UNDER DEMAND ITS JUDDERING AS IF THERE IS NOT ENOUGH FUEL GETTING TO THE ENGINE, IT HAS HAD A NEW SET OF H.T LEADS AND PLUGS AND THEY ARE ALL FINE. RUNNING THE CAR ON PETROL AT AROUND 30MPH IS FINE BUT IT WONT DO OVER 45MPH RUNNING ON PETROL BUT AS SOON AS I TURN IT OVER TO GAS THE CARS AWAY. IT FEELS A DEFINATE FUEL SHORTAGE LIKE THERES NOT ENOUGH FUEL GETTING DELIVERED TO THE ENGINE COULD THIS BE A FUEL PUMP PROBLEM ?????? HAS ANYONE HAD THIS PROBLEM OR HEARD OF THIS HAPPENING??????? CAN ANYONE HELP PLEASE THANKS AGAIN BARRY Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 28, 2008 Share Posted January 28, 2008 PLEASE DON'T SHOUT! Could be fuel pump, or maybe the airflow meter (low airflow means the engine will shove less fuel in) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 28, 2008 Share Posted January 28, 2008 Many LPG kits splice into the engine loom to "steal" signal from the main ECU to control the LPG injectors, and are often less than lovely in their execution - if you see Bodgelok connectors on your loom it's a bad sign. It could also be something related to the timing, if the LPG kit interferes with that to change the timing on LPG it could've buggered up the timing on petrol. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 28, 2008 Share Posted January 28, 2008 The D2 V8 uses a wasted spark quad coil ignition system controlled by the Bosch engine ECU so if it is interfering with the control of that I bet there is plenty of potential to have buggered up all sorts of other things! Quote Link to comment Share on other sites More sharing options...
alex park Posted January 29, 2008 Share Posted January 29, 2008 anyone thought of just the plain old fuel filter blockage? Quote Link to comment Share on other sites More sharing options...
BAZZA999 Posted January 30, 2008 Author Share Posted January 30, 2008 Many LPG kits splice into the engine loom to "steal" signal from the main ECU to control the LPG injectors, and are often less than lovely in their execution - if you see Bodgelok connectors on your loom it's a bad sign.It could also be something related to the timing, if the LPG kit interferes with that to change the timing on LPG it could've buggered up the timing on petrol. Quote Link to comment Share on other sites More sharing options...
tempestv8 Posted January 31, 2008 Share Posted January 31, 2008 anyone thought of just the plain old fuel filter blockage? There's only a filter gauze material that covers the petrol fuel pump, and not an inline fuel cartridge as such. So whilst it is possible, it's not likely to be the fuel filter gauze that is clogged up to the point where it is unable to supply sufficient fuel to the engine. However, it is possible that the fuel pump itself is not capable of delivering enough fuel pressure when the engine needs it. In my experience with the submersed fuel pump in the DII, it does not really like to be running for prolonged periods of time on very little fuel in the tank. The minimum level of fuel that I'd keep in the tank when running on LPG is somewhere between 1/2 and a 1/4. This is to ensure that the fuel pump does not fail. Cheers, Lawrance Lee '99 DII V8 auto with LPG Melbourne, Australia Quote Link to comment Share on other sites More sharing options...
Terry Lee Posted February 5, 2008 Share Posted February 5, 2008 There's only a filter gauze material that covers the petrol fuel pump, and not an inline fuel cartridge as such.So whilst it is possible, it's not likely to be the fuel filter gauze that is clogged up to the point where it is unable to supply sufficient fuel to the engine. However, it is possible that the fuel pump itself is not capable of delivering enough fuel pressure when the engine needs it. In my experience with the submersed fuel pump in the DII, it does not really like to be running for prolonged periods of time on very little fuel in the tank. The minimum level of fuel that I'd keep in the tank when running on LPG is somewhere between 1/2 and a 1/4. This is to ensure that the fuel pump does not fail. Cheers, Lawrance Lee '99 DII V8 auto with LPG Melbourne, Australia Does this mean that the fuel pump keeps running even when on gas? What happens to the fuel, does it recirculate? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted February 5, 2008 Share Posted February 5, 2008 Airflow meter dead. Quote Link to comment Share on other sites More sharing options...
