Headlight Bulb Replacement
enduro1972uk
I have just found that one of my headlights (round ones not square) on my Discovery has blown, i thought that it was a straight forward change old bulb out new bulb in, however i started to read the manual and it says i have to remove the front grill before removing the light assembly to access the bulb. Is this correct? Also how long does the job take? Is it worth changing both of them at the same time?
for what type of discovery ???
For my disco2 facelift, I need to remove:
- A-Bar with light guard
- front grill
- headlamp
then you just change the bulb
