Phil Hancock Posted January 29, 2008 Share Posted January 29, 2008 With the demise of CP Components does anybody else market a power steering kit for series landies? Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted January 29, 2008 Share Posted January 29, 2008 Possibly. Have you looked at TIConsole, the original vendors of that kit? Google for them to see. Otherwise you could: 1. Recreate that kit (its basically some brackets and a ram/pump). All standard stuff. Very simple and probably overpriced. 2. Fit land rover power steering if you don't mind chopping your chassis a little. 3. Fit power steering from something else, requiring more imagination and time. 4. Fit an electric power assist column from a Vauxhall Corsa (DO IT!). Ask Fridgefreezer - has has columns ready to go and a little box of tricks to make it work. Good clean cheap fun. 5. Join a gym. Al Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted January 29, 2008 Share Posted January 29, 2008 what about heystee? Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted January 29, 2008 Share Posted January 29, 2008 Yeah, thats him. Looks like Paul has changed the name of his company. http://www.heystee-automotive.com/ Al. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 29, 2008 Share Posted January 29, 2008 Personally I wouldn't bother, just scallop the front crossmember a little and mount a Land Rover PAS box - they're cheap, readily available, and once the mount is there it's nuts and bolts, a defender column and shaft will bolt to a Series bulkhead. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted January 29, 2008 Share Posted January 29, 2008 Personally I wouldn't bother, just scallop the front crossmember a little and mount a Land Rover PAS box - they're cheap, readily available, and once the mount is there it's nuts and bolts, a defender column and shaft will bolt to a Series bulkhead. Agreed, also, if you cant get the standard hoses to fit nicely, dont comprimise, go have some made and make a nice job of it, they dont cost uber £. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 29, 2008 Share Posted January 29, 2008 Cost me £20 to have two new hoses made to spec, that was to join a Disco 2 PAS box to a BMW PAS pump bolted to a V8 in a 109, so not a standard combo Quote Link to comment Share on other sites More sharing options...
RPR Posted January 30, 2008 Share Posted January 30, 2008 LR PAS box; Saginaw box, Toyota box. All good and relatively straight forward conversions for which there are threads here or in the tech archive to get you started. You will be happy to have it! Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 2, 2008 Share Posted February 2, 2008 If you fit a Toyota PAS box to the outside of the chassis rail, (there is a thread on page 7 in the ''Tools and Fabrication'' forum ), it will free up alot of space for any future modifications such as fitting the radiator and intercooler when doing a 200/300 TDI conversion without the need to rearrange the front crossmember or move it and grille panel forward Defender style.I did notch the top rearcorner of the crossmember to sit the TDI rad down lower to clear the bonnet. However,to clear the steering box at full articulation and full left hand steering lock, wheel rims with greater positive offset .such as Forward Control rims are required.The Toyota box is very reliable, more compact and lighter than the Rover unit, and can be comfortably driven without power assistance in the event of a pump or belt failure. Bill. Quote Link to comment Share on other sites More sharing options...
NRS91 Posted February 28, 2008 Share Posted February 28, 2008 tractor power steering would work(dont start swearing lol) the power steering kit is practically what is used on a tractor...you could mount it down the right of the engine to stop muk gettin into the ram and so it looks practially original if thats an issue Quote Link to comment Share on other sites More sharing options...
jagman Posted May 20, 2008 Share Posted May 20, 2008 Has anyone got any more details on the electric PAS conversion? I gather that it may be preferable to use a non PAS 90/110 steering column and box? IS it possible to simply replace the steering column of a Series 3 with the Cosa electric steering column (with a bit of manipulation obviously). I have doen a forum search but unless I'm missing something there isn't much detail anywhere..... Quote Link to comment Share on other sites More sharing options...
Martin Cooper Posted February 28, 2011 Share Posted February 28, 2011 Heystee kit is good, simple and works. No cutting. Done in 5 hours work. I have their 4 x discs set up too. Equally good. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted March 1, 2011 Share Posted March 1, 2011 This is what I've done to mine: Linky Should be finished this weekend...maybe... Having taken it out for a little test drive, I have to say it's AWESOME! Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted March 2, 2011 Share Posted March 2, 2011 Hi, I have for sale one of the TIC RAM's and the fixing bracket, so not the whole kit but the hard to come by bits. The rest of the bits can all be standard LR bits. I had it fitted to my series 2 for a short while until it failed its MOT. I used a defender power steering pump (mounted up high so it didn't foul the axle as in the original application) and standard LR reservoir. You would also need a double crankshaft pulley (may be able to help with that as well depending what engine you are using). Steering was transformed, very light, lighter than my 90 with power steering. PM me if interested. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted March 2, 2011 Share Posted March 2, 2011 Just noticed how old this thread is!! Probably sorted by now . . . but its here and for sale if anyone is interested. Make me an offer. Cheers Chris Quote Link to comment Share on other sites More sharing options...
