Mark Posted January 30, 2008 Share Posted January 30, 2008 Am going to rebuild a 200TDI to go into the disco, and it is reasnably likley that I will go for a rebore, but it got me thinking about what is possible with this engine. The usual is +20 thou or +40 thou but I wondered if is possible/sensible/feasisble to go beyond this to increase the capacity? A TGV engine is 2.8 and is a 300tdi at heart. How different is the TGV block from the 300, and therfore the 200 block? Would it be possible to use tgv pistons in a 200 block, or are there any other suppliers of pistons that could be used? I am not convinced that custom pistons is the way to go... I realise the TGV has a variable vane turbo, which is probably not a route I will go down, but what else could be done to a 200's internals to raise the power level a touch? Cheers Mark Quote Link to comment Share on other sites More sharing options...
Gromit Posted January 30, 2008 Share Posted January 30, 2008 but what else could be done to a 200's internals to raise the power level a touch? No idea how similar a 200 is to a TGV. There's been a bit of development in between. Turner do uprated heads for the 200tdi, don't they? I wonder do diesels benefit from hotter cams? Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 30, 2008 Share Posted January 30, 2008 You'll struggle to bore enough to increase the capacity that much. Even a 1mm increase will only add 50cc to the engine.So you'd be taking them up by 6mm to get 2.8 at which point ther would be nowt left between the bores. Your only option is a longer stroke crank, which is far preferable anyway as it'll give far greater improvements in torque. As far as I know, the TGV does not have much mods done to the block. I'll now sit back and prepare to be corrected. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 30, 2008 Share Posted January 30, 2008 I believe more than one forumer is running a 2.6/7/8 litre 200TDi although I've no idea what's involved. Quote Link to comment Share on other sites More sharing options...
Mark Posted January 30, 2008 Author Share Posted January 30, 2008 Any idea who John? Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 30, 2008 Share Posted January 30, 2008 Mark, the 2.8 is both bored and stroked. AFAIK there weren't really any changes to the block but the crank, con rods, pistons and head all received a fair bit of attention. Quote Link to comment Share on other sites More sharing options...
white90 Posted February 2, 2008 Share Posted February 2, 2008 Siwhite has a 2.6 in his signature Quote Link to comment Share on other sites More sharing options...
