110 exhausts
anyone know what the difference is between n/a, 200tdi and 300tdi exhausts. i would like to replace my centre section with one of paddock's straight through pipes. i fear my n/a exhaust is of different fitment to either tdi ones and maybe even of different diameter.
so before i go wasting some money on one, does anyone know of any differences?
exhaust upto the 200Tdi use rubber bushes/bolts/nuts on the hangers, 200& £00tdi's have the rubber band ring on a pin hanger at the pipe & chassis brackets.
you need a straight through pipe like this straight through pipe on 110 note the rubber bush type hanger at the rear end
IIRC Bearmach or Britpart do a similar pipe too. the Britpart list Double S pipes in .PDF document
