Serious Series Posted February 3, 2008 Share Posted February 3, 2008 Has anyone any info on removal of top of this pump . Removed mine to replace worn accelerator spindle and seals unfortunately afeter refitting my engine is over revving on start, looks like I have got something in wrong place.Very tricky with three spindles to align. My Engine is 15J Sherpa but pump is same as Defender physically. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted February 4, 2008 Author Share Posted February 4, 2008 Managed to get it back together and engine running but even with new seals and spindle still leaking diesel I will have to obtain new top as this must be worn too. Not sure if DPs pump same as DPA early version but it looks exactly like DPA fitted to 90/110 diesels Couple of pics linked in showing what acts where in case they can help anyone else. When refitting lid push accelerator spinle through and ensure levers A and C engage in correct position. A can be proved by pushing linkage through stop stud hole . If you rotate accelerator spindle anti clockwise then rotate C you will see accelerator spindle move if it is engaged correctly. http://i272.photobucket.com/albums/jj166/p.../Cavpumplid.jpg http://i272.photobucket.com/albums/jj166/p...ver/CavPump.jpg Quote Link to comment Share on other sites More sharing options...
boydy1989 Posted February 28, 2008 Share Posted February 28, 2008 Managed to get it back together and engine running but even with new seals and spindle still leaking diesel I will have to obtain new top as this must be worn too.Not sure if DPs pump same as DPA early version but it looks exactly like DPA fitted to 90/110 diesels Couple of pics linked in showing what acts where in case they can help anyone else. When refitting lid push accelerator spinle through and ensure levers A and C engage in correct position. A can be proved by pushing linkage through stop stud hole . If you rotate accelerator spindle anti clockwise then rotate C you will see accelerator spindle move if it is engaged correctly. http://i272.photobucket.com/albums/jj166/p.../Cavpumplid.jpg http://i272.photobucket.com/albums/jj166/p...ver/CavPump.jpg Hi there, new to these forums! Does anyone have any futher information/pictures/places to get parts for this pump? My LR90 has got a major leak from the injection pump and I gotta fix it with minimal funds and space! All help and advice greatly apprechiated. Advice on where the leak is coming from would also be good - the entire pump appears to be covered in diesel. Many Thanks, Robin Quote Link to comment Share on other sites More sharing options...
Serious Series Posted February 29, 2008 Author Share Posted February 29, 2008 dpa_pump_manual.pdf Hi there, new to these forums! Does anyone have any futher information/pictures/places to get parts for this pump? My LR90 has got a major leak from the injection pump and I gotta fix it with minimal funds and space! All help and advice greatly apprechiated. Advice on where the leak is coming from would also be good - the entire pump appears to be covered in diesel.Many Thanks, Robin If your landrover is a 90 what year and engine size?parts probably still easy to get best wash pump off with gunk or hot soapy watger then look for leaks if its accelerator spindle operate priming pump on fuel pump and you should be able to spot where its leaking from. I have tried attaching a manual for DPA pump not sure if it will attach? Check air bleed bolt on top of pump as if this is loose you can easy fix it. Quote Link to comment Share on other sites More sharing options...
perv Posted February 29, 2008 Share Posted February 29, 2008 The pump you have is a DPS type pump not a DPA. Part no for a non turbo engine is 8520a090a i think, turbo engines are 8520a210a. All parts are still avallable ffrom your local diesel shop. Quote Link to comment Share on other sites More sharing options...
boydy1989 Posted March 2, 2008 Share Posted March 2, 2008 Managed to get it back together and engine running but even with new seals and spindle still leaking diesel I will have to obtain new top as this must be worn too.Not sure if DPs pump same as DPA early version but it looks exactly like DPA fitted to 90/110 diesels Couple of pics linked in showing what acts where in case they can help anyone else. When refitting lid push accelerator spinle through and ensure levers A and C engage in correct position. A can be proved by pushing linkage through stop stud hole . If you rotate accelerator spindle anti clockwise then rotate C you will see accelerator spindle move if it is engaged correctly. http://i272.photobucket.com/albums/jj166/p.../Cavpumplid.jpg http://i272.photobucket.com/albums/jj166/p...ver/CavPump.jpg The 90/110 pump is a DPS. Does anyone here know where i can get a new top for mine, or at least what size the o-ring is for the spindles? I have a serious leak, and am in need of some information before i take the pump apart and disable my car! Many Thanks, Robin Quote Link to comment Share on other sites More sharing options...
boydy1989 Posted March 2, 2008 Share Posted March 2, 2008 dpa_pump_manual.pdfIf your landrover is a 90 what year and engine size?parts probably still easy to get best wash pump off with gunk or hot soapy watger then look for leaks if its accelerator spindle operate priming pump on fuel pump and you should be able to spot where its leaking from. I have tried attaching a manual for DPA pump not sure if it will attach? Check air bleed bolt on top of pump as if this is loose you can easy fix it. It is a 1984 2495 N/A Diesel. I have checked the bleed bolt, it didn't appear to be coming from there - I will try the priming pump trick when I get a chance. How similar is the DPA to the DPS? And I am amazed at how quickly this leak has turned from a minor annoyance to a serious leak, is this likely to suggest that the top of the IP is worn? Quote Link to comment Share on other sites More sharing options...
Serious Series Posted March 3, 2008 Author Share Posted March 3, 2008 It is a 1984 2495 N/A Diesel. I have checked the bleed bolt, it didn't appear to be coming from there - I will try the priming pump trick when I get a chance. How similar is the DPA to the DPS? And I am amazed at how quickly this leak has turned from a minor annoyance to a serious leak, is this likely to suggest that the top of the IP is worn? The accelerator spindle and other spindles just have an O ring fitted once passing will get worse quickly. I have repaired one spindle on my with a o ring from and O ring kit purchased from RS components. Paid £25 for accelerator spindle and new seal. Quote Link to comment Share on other sites More sharing options...
boydy1989 Posted March 4, 2008 Share Posted March 4, 2008 Upon further investigation, i have worked out where the leaks are actually coming from... The top of the stop solenoid The throttle spindle The governer spindle The bleed screw(which is tight) The fuel return line. I think i need a new one... Quote Link to comment Share on other sites More sharing options...
