jules Posted February 3, 2008 Share Posted February 3, 2008 One is a guillotine of some sort but these other one one I'm confused, I've been told its for making body panels but its a mystery to me Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 3, 2008 Share Posted February 3, 2008 Jules Is it not an English Wheel. The 2 wheel that are on the floor end are the bits used. They sit in the vertical plane and you push-pull flat panels through them and it introduces a curve. If you watch American Chopper they use 1 for shaping the fender ( not being a biker not sure of it's UK name.) Seems like a lot of hard work but the results are nice Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 3, 2008 Share Posted February 3, 2008 The one that isn't a guillotine is a wheeling machine for car panel work, wings, etc. Look at a Frosts calalogue (web site) where you can see a man holding a panel in the machine. http://frost.resultspage.com/search?w=wheeling+machine 'Yours' looks in need of serious restoration, and judging by what's on the Frost's site is fairly light weight (motocycle mudguards?). Initially I only looked at the top two results, scrolling down the page there are lighter weight versions for different actions, so 'English Wheel' may well be an exact description. If you end up eBaying it you may need a close up photo of the forming wheels so potential buyers have a clearer idea of the shape that results. Cheers Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 3, 2008 Share Posted February 3, 2008 Sort of the same thing. Just 2 separate bits of kit where as you have them in 1. http://www.northridgetool.com/ Quote Link to comment Share on other sites More sharing options...
Night Train Posted February 3, 2008 Share Posted February 3, 2008 Both are really rusty and needs a good clean up. I was tempted by then in classifieds but they are too far away. The guillotine is a sheer for cutting steel bar or maybe even short lengths of steel plate or sheet, the other is wheel for stretching steel sheet to induce a curve into them. The rollers on then need to be really smooth and polished otherwise they will just roll dents into the sheet. The wheels have a curved profile to them to ease the the sheet thinner where the wheels roll, this makes the sheet spread in a controlled way and so the sheet gets a little curve in it. Depending on how rusty the wheels are they may be beyond saving but new ones could be made on a lathe. I would recommend that they be remachined anyway to get the cleanest surface for use. Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted February 3, 2008 Share Posted February 3, 2008 Both are really rusty and needs a good clean up.I was tempted by then in classifieds but they are too far away. The guillotine is a sheer for cutting steel bar or maybe even short lengths of steel plate or sheet, the other is wheel for stretching steel sheet to induce a curve into them. The rollers on then need to be really smooth and polished otherwise they will just roll dents into the sheet. The wheels have a curved profile to them to ease the the sheet thinner where the wheels roll, this makes the sheet spread in a controlled way and so the sheet gets a little curve in it. Depending on how rusty the wheels are they may be beyond saving but new ones could be made on a lathe. I would recommend that they be remachined anyway to get the cleanest surface for use. that guillotine would never cut steel bar or plate.. its only for thin sheet Quote Link to comment Share on other sites More sharing options...
Night Train Posted February 4, 2008 Share Posted February 4, 2008 I've seen sheers like that handle 10mm bar and crop bits of 4-5mm plate. I guess it depends on the size of the sheer though. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted February 4, 2008 Share Posted February 4, 2008 What they said, the square frame jobber is an English wheel, and the other one is a hand shear / guillotine. They can cut bar etc too, capacity depends on size (that is, blade length, normally) and rigidity, but is usually surprising. Sadly they both look pretty rusty. The useful parts on the English wheel are the rollers, and - since its for panel work, they need to be tip top and smooth. Since at least one of them will be a compound curve, machining to clean them up will probably not be cost effective... Depending on the state of the hand shear blades, they might just need cleaning up or they might need hard-facing/regrinding / replacing. I would have been interested in the shear, but the condition puts me off. Nice to find lying around though - got any more oddball tools you want rid of...? Al. Quote Link to comment Share on other sites More sharing options...
integerspin Posted February 4, 2008 Share Posted February 4, 2008 English wheel;-) you been watching to many yank programs. Yes it's a small wheeling machine. I have seen them that sort of size[i think they were homebuilt], designed for mobile work. There was a bloke near me, a copper smith, he had big old cast iron wheeling machines in his workshop and smaller ones for on site work. I have a bench knife exactly like that, set up spot on it will slice thru 1/4" plate. When you need more leverage you put a length of scaffolding over the handle.. The condition isn't all that bad[the knife] mine got moved outside and sat there since 1989, it only cuts when it's raining now;-) Quote Link to comment Share on other sites More sharing options...
jules Posted February 4, 2008 Author Share Posted February 4, 2008 Yes I have loads more odd stuff like this Boxes of wheels for the panel thing Quote Link to comment Share on other sites More sharing options...
jules Posted February 5, 2008 Author Share Posted February 5, 2008 This I would assume goes with the panel maker anyone think its worth cleaning up and putting on Ebay or is somone on here going to put them to good use Quote Link to comment Share on other sites More sharing options...
