draper40 Posted February 4, 2008 Share Posted February 4, 2008 Hey, I neewd to replce my 1985 csw rear window. Are they all the same? I have found this on on ebay, will it fit? Window How hard are they to fit? Thanks Peter Quote Link to comment Share on other sites More sharing options...
OilIT Posted February 4, 2008 Share Posted February 4, 2008 It is my belief that the frames and glass are all the same (they are handed however so make sure you have the right side - I have tried converting LH to Rh and it wasnt worth the agro). (I have put a 110 glass & frame into a 90 side and it was the same size!) To replace, all you need to do is remove the rubber fillet on the outside edge of the frame, drill out all the rivets and gently pull the frame out of the side panel. Replacement is reversal of removal (sounds like a haynes manual doesnt it!), but make sure you seal around the frame face that mates with the side panel with a mastic sealer before re-riveting. Oilit Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2008 Share Posted February 5, 2008 Side widows sliding type are handed Left or Right. Quote Link to comment Share on other sites More sharing options...
