Finding the high beam wire
Generally blue with a white tracer. I would suggest that the best place to tap into it would be at the fuse box or where the wiring harness goes into the wings. You are using a relay, I take it ?
HTH
Mo
yep got a relay, got the loom, got the lights wired, switch in, everything bar this final wire. Thanks for the tips, gonna tap in tomorrow. Cheers
From memory on older models its white with a blue trace???
QUOTE (Mo Murphy @ Feb 6 2008, 12:37 PM)
HTH
Mo
OH so close.. :blink:
ok, so on the 07 90, the wire running from the switch is blue with a white trace (so like the older versions), I tapped in on the loom, just by the switch high beam switch, and ran a little wire to the other end of the switch for the lightforce. Anyhow will post a photo. Thanks for the tips. Now for the 4 other spots...
