simonr Posted November 24, 2005 Share Posted November 24, 2005 The bottom radiator hoses on LR's - what is the internal diameter of the hose, give or take? Are they all more or less the same? If not, what range of sizes is there - or where would I find out? TIA Si Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 24, 2005 Share Posted November 24, 2005 I have a V8 bottom hose in the garage which I can measure when I get home this evening if no-one else has come up with an answer in the mean time. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted November 24, 2005 Share Posted November 24, 2005 The bottom radiator hoses on LR's - what is the internal diameter of the hose, give or take?Are they all more or less the same? If not, what range of sizes is there - or where would I find out? TIA Si Let';s narrow it down first; which LR are you referring to, Freelander, Early Range Rover, Series 3 Discovery, 101 or the rare centre steer prototype etc.? Series 3 radiator is 35 mm internal diameter, Rover v8 P6 engine are 38 mm internal diameter. I cannot help with any other LRs. Quote Link to comment Share on other sites More sharing options...
simonr Posted November 24, 2005 Author Share Posted November 24, 2005 Let';s narrow it down first; which LR are you referring to, Freelander, Early Range Rover, Series 3 Discovery, 101 or the rare centre steer prototype etc.? Definatly the rare centre steer prototype! Both my defenders are 38mm for both the top & bottom hoses - and I wondered if they were the same across disco's & RR's as well (and even 101's). I may have found a cheap source for silicone hose - but you need to buy probably 10 vehicles worth to make it worthwhile getting it shipped. Looks very bling! Mark - that would be good if you find yourself in there weilding a ruler! Si Quote Link to comment Share on other sites More sharing options...
02GF74 Posted November 24, 2005 Share Posted November 24, 2005 I may have found a cheap source for silicone hose - but you need to buy probably 10 vehicles worth to make it worthwhile getting it shipped. Looks very bling! cheap blingy hose - I'd be interested if you can get hose to connect series 3 rad (35 mm) to v8 water pump (38 mm) with a 45 degree bend it. Quote Link to comment Share on other sites More sharing options...
